Uneven lowering?
Old Mar 7, 2007 | 08:51 PM
WhiteSSBalt's Avatar
Not a Sebring
Uneven lowering?
I noticed that after I installed my Sportlines, one side of the rear of my car will sometimes be lower than the other side. Its not always like this, in fact usually it sits even. However, sometimes on a slight incline (like my driveway for instance), I notice that one side will be noticeably lower than the other....like when you stick my fingers in wheel well, the difference is usually a finger or two, but the front always remains even. I lowered the car properly, did the bumpstop trimming, and all that good stuff. I don't believe either shock is blown/damaged as it rides wonderfully still. Is this normal? If not, whats the hold up here?
Old Mar 7, 2007 | 09:33 PM
DTM2188's Avatar
How new are the springs? Some springs need time to "settle", maybe thats the problem, but I'm not really too sure.
Old Mar 7, 2007 | 09:55 PM
Not a Sebring
the springs have been on since November. I would imagine they've settled as much as they possibly can, haha.
Old Mar 7, 2007 | 09:58 PM
06Pursuit's Avatar
no those springs will need a while to settle. over the summer mine settled a half inch
Old Mar 7, 2007 | 10:26 PM
Not a Sebring
wow that long? I figured 4 months would've done it. Owell, it just looks kinda funky from time to time but I had the same problem with my RX-7 when I had springs on it. As long as it looks good cruisin' then I can't complain too much.
Old Mar 7, 2007 | 10:32 PM
slowbalt19's Avatar
check ur tire tread, my left rear tire had more tread than the right rear and made it seem off
Old Mar 8, 2007 | 10:26 PM
hispano1's Avatar
ya i just noticed the same with my car but mine are used eibachs that i purchased and installed them a day ago and have winter tires on and steelies...every other tirer is 2 fingers, the back passenger is 2 fingers and half of another 1, so i'm wondering if i need to settle these springs as well for a while even though they have been on a cobalt before?? also with the alignment, does it have to be asap or can it be after pot hole season??
Old Mar 8, 2007 | 10:35 PM
Not a Sebring
mine isn't un-even all the time. Only when im parked on certain un-even surfaces. On a normal flat surface it looks fine. However, even with the sportlines, i'm unsatisfied with the overall drop. Granted, it looks nice, and a lot better than stock, but after parking next to a TC riding on Tein coilovers today at one of the local tuner shops, Ptuning, I quickly noticed what a better stance his car had. I eventually will switch over to KW coilovers after I get a few more things I already had planned out for my car done.
Old Mar 8, 2007 | 10:46 PM
hispano1's Avatar
this is when the car is parked on level surface which is in my garage, i just noticed it right now when i parked it and did the finger test...
Old Mar 9, 2007 | 03:03 PM
Mercury's Avatar
my front passenger side is slightly higher than my front driver side. I contacted my spring manuf.(progress) and they said that the car originally might have been higher on one side. I might be switching to H&R race springs soon anyway. I'd get the cobalt addiction coilovers but I don't think they will ever sell them.
Old Jun 18, 2007 | 06:26 PM
snowbred's Avatar
nothing like bringing back a 3 month old thread back from the dead ... my car is doing the same thing on SSC springs, the rear passenger side is higher than the drivers side.. granted i just got my springs put in saturday, should they even out? Is the rear supposed to look like this....https://www.cobaltss.net/forums/show...neven+lowering scroll half way down the page, my rear springs dont look like that in the back. They look pretty spaced out, totally uncompressed. What gives?
Old Jun 18, 2007 | 06:29 PM
06Pursuit's Avatar
i think ur springs are on backwards lol, mine coil together at the bottom.......
Old Jun 18, 2007 | 06:52 PM
snowbred's Avatar
I would think they would be backwards if i had done it myself.. but these were installed by a gm tech. My drivers side isnt coiled either and that side is lowered perfectly
heres the passenger side...
drivers..
Old Jun 18, 2007 | 07:01 PM
RageNRG's Avatar
drivers..
That might be your problem... most of the GM techs I have encountered know jack **** about this car...
Ahh not really... I'm just hating on GM techs... left a bad taste in my mouth.
I have the progress technology springs and havn't noticed any problems. I had em installed at Ptuning in Manassas Va. I'll keep an eye on em and let ya'll know if I notice anything.
Old Jun 18, 2007 | 07:04 PM
snowbred's Avatar
If it helps he also has SSC springs on his gtp with no probs.. He knew i had some good stuff when he saw the ZZP tape on the box cause thats where he gets most of his parts.. i just had them done sat afternoon, so i dont know how quick theyr supposed to settle.. eitherway thats a pretty big difference between the two sides... anyone else help?
Old Jun 18, 2007 | 11:21 PM
GSoccer24's Avatar
mine do that too, i have Sprint springs
Old Jun 19, 2007 | 01:15 AM
snowbred's Avatar
anyone else
Old Jun 19, 2007 | 01:31 AM
1gmfanatik's Avatar
Sorry, I have the Sportlines and love em. I haven't noticed any uneven sitting of my ride, but she is settling a bit since I installed em. Shocks and struts may have an impact also. If one is more worn then the next, that extra wear from the lowering springs may cause this I would believe.
you could also look under the rear of the car and make sure that everything looks seated correctly. VERY easy to install the rears. The springs get slid into place, there maybe a chance that they didn't slide em in correctly, does she creak or have any weird noises comin from her??
Last edited by 1gmfanatik; Jun 19, 2007 at 01:31 AM. Reason: Automerged Doublepost
Old Jun 19, 2007 | 01:49 AM
xravenwingsx's Avatar
i haven't noticed anything making it uneven, but good god the things are harsh around town. gotta love exhaust scraping on speed bumps.
Old Jun 19, 2007 | 07:15 AM
snowbred's Avatar
No creaking at all from the rear. Just the front right side has a slight creaking noise when you turn the well.. i guess i'll just bring the car in on friday and have the guy check it out, maybe something isn't sitting right for whatever reason like you said. He did say if i had a problem he would take them back out and put them back in.
Old Jun 19, 2007 | 06:17 PM
Not a Sebring
lol, its still alive!!! And months later, my car still sits uneven in the rear unless its on a completely flat surface.
Old Jul 10, 2007 | 12:00 PM
OntarioBalt's Avatar
my stock SS/SC sits higher on the passenger rear side like a 1/4 inch..what gives? Hopefully the lowering springs will even it out.
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
