whats the diff?
Old Apr 12, 2006 | 10:40 PM
afireinside1582's Avatar
whats the diff?
whats the difference between a shock and a strut, and which does our car have? sorry, im not very knowledgeable on the subject.
Old Apr 13, 2006 | 02:13 PM
spooler's Avatar
a shock is when you stick your finger in the electrical socket...
a strut is how u walk when you just got laid....
R33P3R007's Avatar
360 L337 User
you rule ....
Old Apr 13, 2006 | 02:37 PM
freakaccident's Avatar
A strut makes up part of the supporting structure of the suspension. A shock does not.
Basically a strut triangulates the suspension. It holds the car up. A shock just bolts onto the existing suspension.
There are other factors and variances but that is it in a nutshell.
Old Apr 13, 2006 | 02:44 PM
jerm's Avatar
freakaccident summed it up really nicely.
Koni explains the difference as this:
"Shocks and struts are similar in that they both damp (slow down) the vehicles motion. The key difference of a strut vs. a shock is that a shock only controls the cars motion while a strut is a locating member of the suspension. What this means is that if you remove a shock the spindle or axle will still be completely attached to the vehicle. If you remove a strut the spindle or axle will be able to move outside of its normal motion. Shocks and struts may or may not have a spring mounted to them either. It is often assumed that any damper with a spring is a strut, this is not the case."
Old Apr 13, 2006 | 02:49 PM
BLKSS's Avatar
I really like spooler's way of saying it...
Old Apr 13, 2006 | 02:52 PM
That makes a lot more sense. I couldn't figure out how to describe it.
Old Apr 13, 2006 | 04:09 PM
player_1's Avatar
AGREED Spooler definition is by far the most accurate
Old Apr 13, 2006 | 05:47 PM
IonNinja's Avatar
I assumed the dampers in the front were struts and the dampers in the rear were shocks. Am I making the wrong assumption according to Koni or am I right?
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
06blackg85ss
Sep 20, 2006 01:16 PM
Wyoming_Bass
Sep 8, 2006 06:11 PM
Mike06cobalt
Mar 31, 2006 08:18 PM
