Wheel spacers (Pictures and informations)
So I got sick of all the misinformations found on this forum and decided to make a new thread in case somebody does researches on wheel spacers in the futur based on the information I have gathered.
1. The biggest spacers you can safely use on the stock wheel studs is 5mm. (you can buy them here.)
2. 5mm wheel spacers is not enough to line up the wheels and the fenders. (imo they're not worth the investment.)
3. You need extended wheel studs (you can buy them here.) for any wheel spacers above 5mm (you can buy them here.)
4. You can use extended wheel studs without spacers and the stock lug nuts will still fit.
5. You DO NOT have to remove the rear hubs to insert the extended wheel studs.
Pictures below is my car on 225/45ZR18 lowered on D2 coilovers using Motorsport Tech 5mm front and 15mm rear wheel spacers.
FRONT BEFORE
FRONT AFTER
REAR BEFORE
REAR AFTER
REAR AFTER
FRONT BEFORE
FRONT AFTER
REAR BEFORE
REAR AFTER
REAR AFTER
