Who sells the KW1 variant coilovers?
Old Feb 3, 2008 | 09:59 AM
LivinModified's Avatar
Who Sells the KW1 variant coilovers?
I was considering getting these coilovers but want to buy from a trusted company. How many people on this forum have them? Are they holding up well, is there any corrosion from salt in the winter?
Old Feb 3, 2008 | 02:28 PM
pacific cobalt's Avatar
I had them for a month and they ride sweet, very firm ride
No Rusting since it's all stainless steel
Buy them from Turbo Tech Racing since Aaron is #1 in customer service
Old Feb 3, 2008 | 02:35 PM
07yellowls's Avatar
go to gravanatuning.com there probably the most complete source on the web right now for the cobalt no matter if your running the LSJ LE5 or the L61 like i have and they have more than just the kw variant 1 wich is what im runin on my 2.2 check em out they got a lot of stuff
Old Feb 4, 2008 | 09:00 AM
do we use the factory strut mounts and bearings for this?
Old Feb 4, 2008 | 09:29 AM
NJBLUESS's Avatar
As far as I know, yes. I'm looking into the KW v2s myself.
Old Feb 4, 2008 | 11:59 AM
TurboTechRacing's Avatar
These are a great kit and we have sold many of these, top of the line product
Old Feb 4, 2008 | 12:04 PM
how long would it take for shipping?
Old Feb 4, 2008 | 04:00 PM
They take about 1-2 weeks as they are special order from Germany.
Old Feb 8, 2008 | 12:26 AM
nybull05's Avatar
they are well worth the wait. I got mine from ttr at least a year ago and still no problems.
Old Feb 8, 2008 | 09:29 AM
Rangerondubz's Avatar
No dampning adjustablility, so I dont like em
Old Feb 8, 2008 | 09:32 AM
the kw variant 2's are dampning adjustable.
Old Feb 8, 2008 | 10:25 PM
KillerBee's Avatar
Cobalt addiction sells them i believe
Old Feb 9, 2008 | 10:53 AM
how strong are coilovers? do i have to worry about bending something in the coilover if i hit a pothole?
Old Feb 28, 2008 | 09:31 AM
I was looking at the KW instructions for installing them on there website and it says the coilovers might need spacers? is this true? are they a direct bolt on or is there some modification necessary? Can I go as low as I want with coilovers with out damaging them?
Old Feb 28, 2008 | 10:30 AM
nybull05's Avatar
well i didnt have to put anyspacers and the were a direct bolt-on and no modifications. But you should get a camber kit if you drop them all the way. i didnt drop mine all the way, so not sur about that.
Old Feb 28, 2008 | 11:28 AM
PlaysWitCars's Avatar
Former Cobalt Owner
rksport has them also
Old Feb 28, 2008 | 08:18 PM
is there a lot of clearance between the coilovers and tires? i checked rksport and they don't list them.
Old Feb 28, 2008 | 08:30 PM
NJBLUESS's Avatar
plenty
Old Feb 28, 2008 | 08:32 PM
Originally Posted by NJBLUESS
plenty
do you have any pics? also where did you buy them from and do you scrape a lot with the coilovers and the gmpp exhaust since the resonator is so big?
Old Feb 28, 2008 | 08:34 PM
Former Cobalt Owner
depends on how much you drop it......
mines all the way down in the rear with a finger width between fender and tire....front is slightly tucked lol
Old Feb 28, 2008 | 08:41 PM
what kind of exhaust do you have? do you scrape alot?
Old Feb 28, 2008 | 08:51 PM
NJBLUESS's Avatar
I base-lined my height to KW's max. spec. front and rear. Compared to stock height it's 3/4 in. lower in front and 1 in. lower in rear. No, I don't have pics. I also do not need the car any lower than it sits now. No scraping at all.
Old Feb 28, 2008 | 08:54 PM
so you just left the coilovers the same height as they came in the box?
Old Feb 28, 2008 | 09:20 PM
NJBLUESS's Avatar
No, you need to adjust the initial setting. The directions are good to guide you through that. Fronts require 2.6in. of exposed thread and rears are 1in. exposed thread on the strut body and rear adjusters.
Also, I purchased mine through TH Motorsports. No problems at all, service and shipment were great.
I was going to do a write up about them, but nobody showed interest when I started a thread.
If your serious about a suspension system, KW is just about your top choice.
Old Mar 7, 2008 | 09:42 AM
can air tools be used when installing these coilovers or does everything have to be torqued to spec?
