60lb flow at 43.5 psi
I have a question about the 60lbers from a few websites i have seen the 60's we are buying are 60 lbs/hr at 43.5 PSI but our fuel pump is at 56 PSI. so does that mean they could flow more at a higher psi but are limited by our stock PCM or do they flow less at a higher PSI. im no injector expert but i saw that and it was a question i have.
Here is the link to gm's website that says our stock fuel pump is rated at 56 PSI
http://media.gm.com/us/powertrain/en...2007/07car.htm
After that the computer loses control of the injectors basically, and the rest of you flow has to be rigged to compensate for the differences.
I think I remember calculating them a while back, and they go into the 80#/hr range, but that was about 10 months ago.
It varies according to manifold pressure. Returnless systems don't compensate for manifold pressure which is why we have an injector flow rate table. At 20psi boost the flow is nearly identical to a 3bar pressure regulator, but under vacuum they flow even more, outside the range of the IFR table and makes them harder to tune for low pulse widths.
