big tuning problem
Old Feb 27, 2008 | 01:48 PM
Raven SS's Avatar
<---------refers back to punching the tuner in the nutts as stated in post 11
Old Feb 27, 2008 | 01:49 PM
lsjwannabe's Avatar
yeah thats where the problem is
EdCobaltSS's Avatar
check and make sure the tuner shut off boost control in 2nd 3rd and 4th gear, ive seen this problem b4 on a dyno.
Old Feb 27, 2008 | 01:54 PM
freakta's Avatar
id have to ask him cause i dont have the car right now. my car since the time i got it has boosted directly to 10psi then climbed slowly to 12 now that it revs to 7k it jumps to 10 psi then climbs slowly to 15.
Old Feb 27, 2008 | 02:00 PM
Area47's Avatar
Rent me! per hour
also, tell you tuner to stop being a pansy with the timing and fuel.
Old Feb 27, 2008 | 02:01 PM
freakta's Avatar
ill let him know he is a pansy but i did specify to him that i need to be safe not stupid safe but the car is a daily driver. my race car is a diff story
Old Feb 27, 2008 | 02:02 PM
lsjwannabe's Avatar
well thats why your not making the power right there. Also don't look at peak numbers, look at the numbers under the curve to see where you gained our power
Old Feb 27, 2008 | 02:04 PM
Raven SS's Avatar
i think all of us in here giving u some pointers are dd's also lol
Old Feb 27, 2008 | 02:08 PM
lsjwannabe's Avatar
yeah i am too
Old Feb 28, 2008 | 12:27 AM
freakta's Avatar
well we took off my brand new zz downpipe and the cat is messed up pretty bad. so we cut it out. put in a test pipe and the check engine light finally came on and the car got better gas milage and seemed to run much better. we will dyno it tomorrow night to see what if anything happened
Old Feb 28, 2008 | 12:30 AM
  #36
Raven SS's Avatar
theres where ur new found boost came from lol...now lean it out and add some timing
Old Feb 28, 2008 | 11:23 AM
  #37
freakta's Avatar
so here is an odd question when i hit the gas should the car immediately hit full boost or should the car wind out a bit at the top end
Old Feb 28, 2008 | 11:24 AM
  #38
lsjwannabe's Avatar
hit full boost usually depending on the gear and rpm
Old Feb 28, 2008 | 11:26 AM
  #39
Raven SS's Avatar
^^^ what he said..u can putt around barely going into boost but if u lay into it..u should jump into full boost
Old Feb 28, 2008 | 12:03 PM
  #40
freakta's Avatar
my car has never done that. its always hit a number like 10 or 7psi then wound out as i got further into the rpm range
Old Feb 28, 2008 | 12:17 PM
  #41
MatrixMotorsports's Avatar
the last 2-3 psi can come later on, thats not unusual.
Old Feb 28, 2008 | 12:29 PM
  #42
Area47's Avatar
Rent me! per hour
that is torque management doing that one. not the blower itself.
Old Feb 28, 2008 | 12:51 PM
  #43
freakta's Avatar
o... i didnt know what torque mngt was
Old Mar 1, 2008 | 12:58 PM
  #44
freakta's Avatar
ok new fun.... it made 255whp and 232tq
its not the hp i thought but its more tq than i thought
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
