clearing codes on 07 lsj and 06 2.4
Old Oct 17, 2008 | 01:05 AM
Zdeuce4's Avatar
Ok,
My friend and i are gonna finally tackle clearing the CEL codes caused by our catless dp's. After we select all the correct codes, the 07 ss/sc can just be flashed right? and for the 06 2.4 i will have to do write entire so that it gets the entire thing and doesnt screw up?
Old Oct 17, 2008 | 01:08 AM
ItalianJoe1's Avatar
Why do you have to do a write entire? I thought you just changed the setting on the p0420 code and did a quick write, and good to go?? Worked for me and several others.
Old Oct 17, 2008 | 01:19 AM
Zdeuce4's Avatar
cuz i have an 06 2.4.. last time i tried quick write it locked out my entire ecu..car would not start. i will never do that again
Old Oct 17, 2008 | 01:27 AM
REIGN SS's Avatar
Original Hayden Fanatic
From what I've read the 2.4 do require a full re-write
Old Oct 17, 2008 | 01:36 AM
I remember hearing somthing like that, I was just under the impression that a full write can cause more issues than a partial write, so it is generally discouraged.
Old Oct 17, 2008 | 09:14 AM
Zdeuce4's Avatar
at the moment all i wanna adjust is the code clearing... besides that nothing else...
Old Oct 17, 2008 | 03:39 PM
Zdeuce4's Avatar
can anyone verify that all the 07 needs is the quick flash?
Old Oct 17, 2008 | 06:08 PM
every cobalt i've ever done has only needed a quick flash, even for big changes. They were all LSJs though, so the LE5 might be different, can't say.
Old Oct 17, 2008 | 06:12 PM
slowswap's Avatar
All 2.4's require a write entire every time or you will be locked out of the ECU.
Old Oct 19, 2008 | 04:16 PM
pjk91's Avatar
all le5's require a write entire.
Old Oct 19, 2008 | 07:43 PM
Zdeuce4's Avatar
i got it to work correctly...thnx for the help... one issue tho is i cleared 5 codes and it came back on.. my buddy wouldnt check all the codes before we did it.. so im gonna have to try again.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Sep 28, 2015 12:51 PM
