E37 Tuning
#76
numb nuts.I checked a million times for vacuum leaks and what do you know...nothing.Being ASE certified in multiple fields I know how to look for leaks lol.way to be an ass
#78
Being ase certified in parts dosnt count and yes a leak or unmeterd air will cause a rich conditOn bc when ur fuel trims go to positive it will start dumping fuel like woah if u think Vince is full of **** get a scan took look at ur ltft's I bet there prolly 15-20% positive but what do I kno it's not like I do it for a living
#79
LOLz.your stupid man.And yes never heard of a vacuum leak making a car rich neither have any of the other techs ive talked to and personally never had/seen a car go rich with vacuum leaks.seen a dickload go lean but none rich.And my car does not have a vacuum leak.god people here(especially trifecta leg humpers) are dicks lol.
#81
i'm not saying vince is 100% perfect he's not.. but i think you're going to be disappointed when you find out you cant get your AFR to be what it should be because you have a leak.. again.. good luck
not going to ***** up this thread that actually has progress with just random ****
#82
hahahahhaha yeaa i wasn't going to get into the specifics of how i had a rich condition because of a leak and how we figured out where the leak was..
ok im done E arguing ha.
#83
didnt know you knew me and my certs lol oh btw your forgot just a couple other than parts haha.good try though anyways like I said the tune sucks and even getting a response from the last data log(4 months ago)is a little annoying so vince is out and ill have my more experienced local tuner do work.Never seen a 2.2 NA run 15.4(quarter mile) on a vacuum leak.kind of weird.anywho back on topic good chating with you.
and like I said my car does not have a leak.so please shut the hell up already lol
i've seen 2.2's without vacuum leaks run 15.0s as well as high 14s.. dont brag about a 15.4 lol
#85
thanks for luck just searched for leaks again.none and talked with my tuner and yet still confirmed its the tune.so ill stick with an experienced tuner and adjust fuel trim.Dont get me wrong the trifecta tune on my buddys turbo 2.2 is pretty good. but mine is just stupid rich at WOT.sits stoich at idle and crruising but WOT will touch 10:1 then go to 11.5.Id just rather have the tuner right then and there,sorry if I was being a dick,but this tuning process really sucks so HPtuners will be a easier process.
#86
-Bill
Mapping is coming along well, we'll probably have the second def done sometime next week.
#89
Awesome!Ill get with steve again.Thanks.
#91
This E37 thing has been a long time coming. It's about time. Thanks for taking the time to work with these cars.
That's not true. The 2.2L Ions with the E67 ecm have been supported and tunable by HPTuners for a LONG time. Have you tried one? It even reads the automatic transmissions and those are tunable too.
That's a possibility. As far as I know he's the only person whos tried to find the vacuum leak on his car and to no avail. Maybe it's just not something obvious or maybe he passed it over.
#92
#93
Tested it again and Hptuners connected to the vcm but would not allow any edits other than throttle motor and idle.so we sent more data in for them to overlook and hopefully this gets fixed soon
On a side not had my tuner look at all the parameters and came to the conclusion that i do not have a vacuum leak.weird...I was almost convinced that I had one seeing vince is never wrong.just thought I would share.
#98
