fuel pump limit
Old Nov 6, 2009 | 05:34 PM
BlackMagic's Avatar
fuel pump limit
how large of injectors can the stock fuel pump support?
Old Nov 7, 2009 | 12:29 AM
StreetDreamz's Avatar
Depends. You could run 80s no problem, but if you're on a Harrop with a 7500rpm redline, you'll be maxing it out for sure.
Old Nov 7, 2009 | 01:40 AM
Area47's Avatar
Rent me! per hour
depends on your power adder
Old Nov 7, 2009 | 03:02 AM
InfraRedline's Avatar
Listen REAL close to what these two say on this subject. Both are running TVS with 1000cc injectors IIRC so they have some recent experience with teh pumps limit.
Old Nov 7, 2009 | 08:43 AM
Jrhdpaintball's Avatar
area just did something to his fuel pump or system, to help fix it for awhile.. didnt say what it was...any clues
Old Nov 7, 2009 | 06:53 PM
advise's Avatar
boost reference?
Old Nov 8, 2009 | 10:51 AM
BlackMagic's Avatar
I'm keeping the m62 for now anyways. I was thinking of running e85 and dropping the pulley size.
Old Nov 8, 2009 | 10:57 AM
1badBlueberrySC's Avatar
You'll be fine with 60's on the M62
Old Nov 8, 2009 | 11:31 AM
BlackMagic's Avatar
I was planning on using a 2.7 pulley. 80's then?
Old Nov 8, 2009 | 11:35 AM
ShortStack's Avatar
2.7 is fine with 60s
Old Nov 8, 2009 | 12:23 PM
Yes 80's with E85. With pump gas 60's are fine.
Old Nov 10, 2009 | 12:35 AM
I just went to a return system and Walbro 255hp pump. Even with a base pressure of ~45psi, meaning around 70psi by redline, I am almost maxing out the 1000cc injectors commanding a .78 lambda. E85 is hungry for volume lol. The stock pump would **** out around 6000rpm, but that's because it's flowing at 58psi and dropping steadily from there. I can't say what it would do if asked for more pressure. I imagine it would just explode lol.
Old Nov 10, 2009 | 12:44 AM
Area47's Avatar
Rent me! per hour
did you mod the 255?
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
