help with hp tuners
Old May 10, 2008 | 05:45 PM
nuttzzy's Avatar
help with hp tuners
ok im new to tuneing i have 60 lb injectors an a 2.8 on the way i read somewhere about tuneing your mass air flow to match your injector rate by useinging the histogram tables?? to get these you have to run a scan right? im all confuse with this. can some make it easier for me? i installed a aftermarket h/e and in getting about 30 degrees diffrence between IAT and IAT2 i also set my fans to come on at 40% minimum at 200 is this bad it have them running alot? so im learning somethings but for some reason im not grasping fuel ratios
Old May 10, 2008 | 07:46 PM
SJSchafer's Avatar
I just wrote a how to on tuning for 60s. It'll be there as soon as the mods approve it. It sounds like you may need some basic info first, so I would do a search for MAF tuning, to start with.
Old May 10, 2008 | 09:58 PM
nuttzzy's Avatar
yeah i just got some of that what the optimal perfect afr for the lsj?? 11.4??
Old May 10, 2008 | 10:02 PM
SJSchafer's Avatar
Cool. Yea 11.4 is a good spot for WOT PE. I was running mine at 11.5
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
