How the tuner knows reached the limit ?
Hello,
I have a question:
How the tuner knows that can't go further getting out power from an engine, in this case an LNF ? In other words : How he knows reached the limit ?
I have a question:
LOL!
I'm just curious.. never will try to tune my car, I'm good crashing my cars but for sure will do worst tuning them.
I got a really smart answer from a tuner that basically say ".. there is no way to find the limit by following a book, only guessing based on years of experience"
That's why make sure to get a large experience tuner before trying to mod your car..
I dont think hes trying to tune his own car. Hes asking a question of how far a tuner can take a car before he knows the tune will turn the internals into externals.
For OP, pretty much if hes going ***** to the wall, once it starts knocking, thats where he'll stop.
Most people who want a conservative tune will keep the stock timing map or have a slightly modified one, but for all out power, one you start to see knock retard, youve pretty much hit the limit with timing at least. Switching to a different fuel could aid in the further advancement of timing.
As for fueling thats kind of self explanatory, it will run its best at a specified afr(not exactly sure how thats determined) but adding more fuel will eventually start taking away from the power.
I am not an expert on this at all, just going off of what i know. There are many tuners on this site that should be able to help you answer this better than i can.
To be honest, I hope the tuner is looking at the logs of some start and end speed. Say 60-90, or something. Should be a 3rd gear pull. Stop throwing more timing at it when the 60-90 time doesn't improve because the car is making the most power, and more timing isn't gaining anything. You don't stop when it's at the edge of knocking, good god that would be horrible.
Have any of you ever watched Horsepower TV? It's on Spike on Sat/Sun. mornings. When they are dyno tuning a new car/motor, they keep adding timing until the power doesn't increase anymore, then they back it down a smidge for safety. They never run it up to detonation and then back it down a smidge .
"Generally" with boost and pump gas, kr is reached before Peak tq/hp. And I say generally very loosely. High hp builds I require a dyno tune regardless.
I have seen peak power drop with additional timing and no kr multiple times on e85, even at 500whp.
z28addiction
09-28-2015 12:03 AM
