HP Tuners LNF release info
Old Mar 24, 2011 | 01:24 AM
HP Tuners's Avatar
Not Work Safe HP Tuners LNF release info
Guys,
Here's the news on some new stuff that will be in beta in the next couple of days. Please email support at hptuners.com for access to the beta.
Please use the subject line:LNF Beta and your serial number and as soon as the software compile is ready I will send out all the emails.
Boost
- MAP sensor Linear
- MAP Sensor Offset
- Prop Gain
- Int Gain
- Deriv Gain
- Prop Gain Steady State
- Steady State Boost Enable
- Prop Max
- Wastegate DC Correction factor
- Wastgate DC Max
- BOV Surge Limit Upper
- BOV Surge Limit Lower
Fuel Pressure
- Desired Fuel Pressure Normal
- Desired Fuel Pressure A
- Desired Fuel Pressure B
- Fuel Pressure A Select
- Fuel Pressure B Select
- Pressure Type
- Fuel Pressure Max
- Fuel Pressure Min
- Fuel Pressure Fixed
- Fuel Pressure Positive Ramp Limit
- Fuel Pressure Negative Ramp Limit
- Desired Rail Pressure PID
Injectors
- Injector Constant
- Injector Pulse Mult
- Injector Short Pulse Correction
- Injector Flow Mult
- Injector Offset
- Pulse Width Min
- Combustion Pressure Factor
- Homogenous Single Charge Thresh
- Injection Angle Homogenous Single Low
- Injection Angle Homogenous Single High
- Injection Angle Homogenous Knock Intake
- Injection Angle Homogenous Knock Comp
- Injection Angle Homogenous Double Intake
Spark
- MBT Spark Int Min, Ex Min
- MBT Spark Int Max, Ex Min
- MBT Spark Int Min, Ex Max
- MBT Spark Int Max, Ex Max
Fans
- Fan Desired % ECT
- Fan Desired % AC
- Fan Speed Select
-HPT
Old Mar 24, 2011 | 05:49 AM
Sweetsandman's Avatar
I'm angry
Old Mar 24, 2011 | 08:48 AM
Iam Broke's Avatar
Not me, competition is a good thing.
Old Mar 24, 2011 | 09:53 AM
Well, I'm only angry because I sold HPTuners thinking I was getting rid of my car...silly me.
Old Mar 24, 2011 | 10:19 AM
SCcobaltSS's Avatar
Just buy it again.
This is huge, cant wait to get the beta so I can play around.
Old Mar 24, 2011 | 10:24 AM
Originally Posted by SCcobaltSS
Just buy it again.
Well I bought my Trifecta stuff once I decided to keep the car. I'll probably get HPT again if the big turbo goes on.
Old Mar 24, 2011 | 11:23 AM
wantedSS/TC's Avatar
win!
Old Mar 24, 2011 | 11:36 AM
JPizzle's Avatar
Awesome! I can't wait!!
Terminator post what you think! Haha.
Old Mar 24, 2011 | 12:02 PM
umrdyldo's Avatar
Looks like some nice add ons.
Old Mar 24, 2011 | 12:10 PM
Chevycobaltss3's Avatar
Hahahahahahahahahahahah great news
Old Apr 5, 2011 | 09:50 AM
Iam Broke's Avatar
Updated list of tables & scanner cfgs to be posted in the beta soon...
Boost
- MAP sensor Linear
- MAP Sensor Offset
- Prop Gain
- Int Gain
- Deriv Gain
- Prop Max
- Wastgate DC Max
- MAP Sensor Low Fail (P0107)
- MAP Sensor High Fail (P0108)
- MAP Sensor Range Low (P0106)
- MAP Sensor Range High (P0106)
- MAP Sensor Range Tolerance (P0106)
- Boost Sensor Linear
- Boost Sensor Offset
- Boost Pressure Limit
- Boost Sensor Low Fail (P0237)
- Boost Sensor High Fail (P0238)
- Boost Sensor Range Low (P0236)
- Boost Sensor Range High (P0236)
- Boost Sensor Range Tolerance (P0236)
- Pressure RPM Factor
- Pressure IAT Factor
- Pressure Flow Factor
- Turbo Thermal Load Limit
- Fault Airload Reduction Factor
- Severe Fault Airload Limit
Fuel Pressure
- Pressure Type
- Fuel Pressure Max
- Fuel Pressure Min
- Rail Pressure PID
Torque Management
- Load Damping Enable
- Load Damping Throttle Torque Limit
- Load Damping Mult
- Load Damping Mult 2
Injectors
- Injector Constant
- Injector Offset
- Pulse Width Min
Spark
Fans
- Fan Desired % ECT
- Fan Desired % AC
- Fan Speed Select
Old Apr 5, 2011 | 10:05 AM
foff667's Avatar
New beta up guys
Old Apr 5, 2011 | 10:07 AM
Terminator2's Avatar
Originally Posted by foff667
New beta up guys
Awsome, Thanks Bill. Time to play some more.
Old Apr 5, 2011 | 10:09 AM
BYT*SS*TURBO's Avatar
HP at it again! Even more tables, and so soon
Old Apr 5, 2011 | 09:08 PM
Iam Broke's Avatar
CAT Warmup disable!!!
Old Apr 5, 2011 | 10:58 PM
T-Man's Avatar
Was so nice not having to deal with that for a change. Can only imagine you guys with DPs and catless DPs...
Old Apr 5, 2011 | 11:05 PM
So they put cat warmup on there?????
Old Apr 5, 2011 | 11:06 PM
FF_ace's Avatar
good work now i just need to slap my big turbo on and let terminator work his magic
Old Apr 5, 2011 | 11:27 PM
jboogie's Avatar
Can't wait to see you tuners work your magic with the new goodies! The new spark tables should help my low boost tune when it's time.
Old Apr 7, 2011 | 10:20 AM
Your car is going to be an absolute monster when it is done.
Old Apr 13, 2011 | 02:29 PM
RoadconeTuning's Avatar
BOV Surge Limit -LNF
what does this mean? what does it do?
Old Apr 13, 2011 | 02:50 PM
foff667's Avatar
It means you are virtually limitless tuning wise now. If you are going to max out anything now it'll be hard parts, not the pcm's capabilities.
Old Apr 13, 2011 | 04:05 PM
you missed the subject of my post. i'm aware of the overall good that this release does but what is the BOV surge limit function do? google search, HPTuners Forum Search and CobaltSS.net search netted zero results other than this thread posted everywhere lol
Old Apr 13, 2011 | 11:53 PM
foff667's Avatar
Scroll over help file is likely the info we have on what it does.
Old Apr 14, 2011 | 12:00 AM
ssyellow's Avatar
Good work. Thanks for helping out the community.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
patooyee
Oct 1, 2015 01:07 PM
