Injector troubleshooting
So I got my injectors in and I installed a Tune that I thought would be right. Car runs fine but my CEL is on. any ideas on why? ive got an 08 LS, I went from stock injectors to the stock LSJ injectors.
+1 let us know what the code is and we can go from there. I would guess you are either using the wrong settings, or if it's running fine then it's probably a rich/lean code from your fuel trims being off. Hard to say though without any more information.
Yeah. Thats the table that was on the stock tune. My car isnt an ss you know. Anyways. The isnt running hot, so that probably means the CEL is Rich, right? The unit is flow g/sec
First off, why did you change injectors if you didn't add power? Secondly, without knowing the code we can't tell you what is wrong. Thirdly if the code went away, it's probably a rich/lean code that worked it's way out. From your signature all I see is Injen SRI that adds power, with that being said, there was no reason to change the injectors/tune and go through this trouble lol.
Fail Less.
If it went away and doesn't come back, you're probably fine.
I don't like the kid, but Zach has a point. CAI with 2.4 IM/TB puts you nowhere near maxing out the stock injectors. You likely lost power by putting in the injectors if you are running an incorrect AFR and have no way of monitoring it.
Atleast get a tune from Trifecta based on some datalogs...
