Ipw Pid ...
Old Sep 1, 2007 | 09:38 PM
Jmc007's Avatar
Ipw Pid ...
It seems that the HPTuner Preset PID for my IPW is wrong, it gives exactly half of the value it's supposed to be.
How to create a custom one, should i be hooked to the car ?
Old Sep 1, 2007 | 11:35 PM
foff667's Avatar
Are you sure about this? Mind posting your scan showing this? Sounds as if your talking about injector duty cycle showing 1/2, which is NOT a pid it is a calculation using several other PID's in said calculation, of what its supposed to be in which case look to see if your logging injector pulse width for bank 2(which you don't have a bank 2) which could cause your injector duty cycle to read the way your saying.
There are a bunch of config files on our forum made specifically for 4 cylinder cobalts so you might want to mosey on over to check some of them out
Old Sep 2, 2007 | 12:03 AM
M-Dub's Avatar
the pid file that comes with hpt, for the idc side of it is wrong. how ever the Msec readings are correct.
doc posted a file on hpt forums, which is set up right for the idc calculations.
-Area47
Old Sep 2, 2007 | 12:14 AM
foff667's Avatar
-Area47
All it takes is deleting the bank 2 pid's in the table display which all show bad data due to the fact that there is no bank 2 on 4 cylinders
Check out the config & histogram repository as there are many config files specific to cobalts already made
Old Sep 2, 2007 | 02:31 PM
Jmc007's Avatar
Neither worked, I made a custom PID by multilplying the original by 2 (and back check to see if it's right) and now it's working.
Turbo Johnny
Feb 21, 2019 09:41 AM
n20saturn
Tuning
Sep 7, 2015 11:56 AM
Jmc007
Oct 14, 2005 09:46 PM
bigjoe25
Drag Racing
Aug 4, 2005 09:45 AM
mchat
South Mountain
Jun 30, 2005 08:52 PM
