Ipw Pid ...
Ipw Pid ...
It seems that the HPTuner Preset PID for my IPW is wrong, it gives exactly half of the value it's supposed to be.
How to create a custom one, should i be hooked to the car ?
Are you sure about this? Mind posting your scan showing this? Sounds as if your talking about injector duty cycle showing 1/2, which is NOT a pid it is a calculation using several other PID's in said calculation, of what its supposed to be in which case look to see if your logging injector pulse width for bank 2(which you don't have a bank 2) which could cause your injector duty cycle to read the way your saying.
There are a bunch of config files on our forum made specifically for 4 cylinder cobalts so you might want to mosey on over to check some of them out
the pid file that comes with hpt, for the idc side of it is wrong. how ever the Msec readings are correct.
doc posted a file on hpt forums, which is set up right for the idc calculations.
-Area47
-Area47
Check out the config & histogram repository as there are many config files specific to cobalts already made
Turbo Johnny
Feb 21, 2019 09:41 AM
