LC-1 Question
Old Feb 5, 2008 | 01:55 PM
Raven SS's Avatar
LC-1 Question
since the thread hasnt been updated on how to connect the wideband...i was wondering if anyone has connected a lc-1 to hpt pro? i know the lc1 has a usb cable but how do it work with hpt? ive only worked with aem
Old Feb 5, 2008 | 01:59 PM
Omega_5's Avatar
There should be a single 0-5V wire coming off the module. Plug it into the input terminal.
Edit:
Found the right link....
http://www.hptuners.com/forum/showth...=lc-1+wideband
Old Feb 5, 2008 | 02:00 PM
Raven SS's Avatar
the white one right?
Old Feb 5, 2008 | 02:01 PM
Omega_5's Avatar
Either the yellow or brown... they are the same signal.
Edit: White is the system ground.
Old Feb 5, 2008 | 02:02 PM
Raven SS's Avatar
see im getting mixed feed back on this because the help on hpt says to take the outputs and put them to the 1 and 5 spots on the mpvi
******* headache...why cant everyone buy a plx or aem
Old Feb 5, 2008 | 02:05 PM
Omega_5's Avatar
Sorry... here is the exact wiring...
Hook the brown wire up to pin 1 on the EIO.
Hook up the black wire to pin 5 in the EIO.
Image...
Old Feb 5, 2008 | 02:09 PM
Raven SS's Avatar
life saver...so i run a wire from the connector to the 5 spot then the brown wire off of the gauge to the 1 spot...perfect
Old May 11, 2008 | 01:12 AM
nuttzzy's Avatar
sweet this helps me out alot will hpt make corrections by itself to maintain a certin afr if you have it hooked up?
Old May 11, 2008 | 01:22 AM
SJSchafer's Avatar
Hmmm. I've never seen that before. I.ve never had anything plugged into #5 of the pro interface. Just 1 wire to the #1. Works perfectly.
Old May 12, 2008 | 04:01 PM
Raven SS's Avatar
holy old thread bump batman
Old May 12, 2008 | 04:03 PM
SJSchafer's Avatar
Oh, you mean that you don't need help with this anymore? Has your car actually ran since 2/08?
Old May 12, 2008 | 04:05 PM
Raven SS's Avatar
lol i dont own an lc1 ass...i tune people but not everyone has a uego
Old May 12, 2008 | 04:06 PM
SJSchafer's Avatar
Oh. I am so sorry...
...for you.
Old May 12, 2008 | 04:15 PM
Raven SS's Avatar
lawl...
Old May 12, 2008 | 04:18 PM
silentd's Avatar
this way does display wideband not narrow correct?
Old May 12, 2008 | 04:23 PM
Raven SS's Avatar
yes these are the wires that come off ur wideband to the mvpi
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
