Lean in low gears
Old Jun 17, 2007 | 10:23 AM
Maxim_X's Avatar
Lean in low gears
Well, I'm running really lean in 2nd. It hits 13's . But when I shift 3rd I go down to about 11.4. Other then that my tune it pretty good. Any Ideas???
Old Jun 17, 2007 | 09:23 PM
cobi's Avatar
where at in second? and is this WOT or what?
Old Jun 17, 2007 | 09:47 PM
foff667's Avatar
Have you turned COT off completely?
Old Jun 17, 2007 | 09:50 PM
BriantheLion26's Avatar
Would the fact that you are running a 2.79" pulley on 42s (I am assuming) be the problem? I thought a 2.9" was pretty much putting the injectors at 100% duty. Just my thoughts on the problem.
Old Jun 17, 2007 | 10:08 PM
cobi's Avatar
they max out but they still get out the fuel they are just working way to hard to do it. Its usually over 100% duty
Old Jun 18, 2007 | 04:13 AM
Maxim_X's Avatar
I'm on 60's. And no I did not disable COT... What is that, How do I do it??
Yes I am at WOT.
Old Jun 18, 2007 | 11:00 PM
tunerpro's Avatar
is this problem persistent throughout the entire rpm range or simply up top...?
Old Jun 19, 2007 | 01:00 AM
foff667's Avatar
Yes I am at WOT.
I would think this is your problem
your tune down low is probably just off and your tune up top is being compensated richer by COT. Delete COT and get your tune right or just plain old get your tune right
Old Jun 19, 2007 | 11:15 AM
Area47's Avatar
Rent me! per hour
load difference for starters.
second piston protection, and cot.
Old Jun 19, 2007 | 04:01 PM
foff667's Avatar
Generally speaking your going to have more load the faster your going ie the higher gears. Meaning a leaner mixture at the top end rather than a richer mixture which is the case here.
Old Jun 19, 2007 | 04:20 PM
Area47's Avatar
Rent me! per hour
to a degree
Old Jun 19, 2007 | 05:54 PM
foff667's Avatar
to a degree
Explain the other degree then If you will.
Old Jun 19, 2007 | 06:00 PM
Area47's Avatar
Rent me! per hour
depends on how fast you go through the gear, like 1st and 2nd.
you can blast through these. IE a 400 whp honda that spends very very little time in these gears. these gears could be a ton leaner due it having a low load, vs 3rd 4th gear where it finally is able to put a load on the car and get the a/f down
Old Jun 19, 2007 | 08:08 PM
Maxim_X's Avatar
I think what I need to do is put more fuel into the higher rpm lower load.
I still don't know what COT is or how to disable it.
It was leaning out after about 4k.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
tomj77
Oct 4, 2015 11:39 AM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
