LSJ e85 Kr with someone conservative timing
as the title says, running E85(E78) with some somewhat conservative timing , and im getting random occurrences of knock ,not sure if its real of false.
each run is same tune about 30 mins apart
that timing table isn't very conservative at all, that knock is 100% real
24* at peak torque is pretty dangerous imo, read up on how to make a spark table then try again
also why is your VE airflow so fucked?
who said im not?, I'm not in disagreeanc id just like more info, rather than vague simi worthless comments. VE is fucked up because i haven't touched it,its a maf only tune. until i can get to a dyno
i guess its hard to see but the knock is in between shifts and after 6000rpm with the exception on the knock at launch which i know is false because it always there even when i take off normal ,and it was there when i was on the super conservative GMPP SII tune. Its mostly the kr between shifts and at 6krpm that i'm suspicious of.
My VE is way jacked. Id rather use adjustable load dyno. what could be easier than letting the dyno do all the work, its the only way to get enough hits in every single cell.
Macgyver2484
Sep 2, 2015 05:44 PM
