need tune help now!!!
Old Mar 3, 2007 | 11:06 AM
607Motorsports's Avatar
I'm in a big dilema here so anyone who can please help that would be amazing. I just did my install last night for my Intense kit. I am running a 2.7" pulley, 60lb injectors, and the air box mod and that's it. After getting the CPS (crank positioning sensor) relearned this morning I attempted to get on the car coming back from the dealership. The car is so rich it just dogs out and throws **** loads of black smoke out the exhaust. Intense was supposed to have tuned the car for my supporting mods but this definately isn't right.
I need your guys help asap seeing this is my daily driver and I can't really afford any downtime. I have HPTuners and have tuned my Cavalier with it but I haven't done much with MAF tuning. Can someone help me out with a 2.7" 60lb tune that will work for my car? I do have one tune I got awhile back for this setup if someone wants to take a look and maybe edit it for me.... pleaseeeee
Hell I'm even willing to pay a fair price if need be, i'm desperate here
Old Mar 3, 2007 | 11:08 AM
distillion's Avatar
get a hold of tag, they have a tune for a 2.7, probably mine lol
Old Mar 3, 2007 | 11:14 AM
How would I get ahold of TAG? I need a tune asap!
Old Mar 3, 2007 | 11:17 AM
distillion's Avatar
call them or pm mase, im pretty sure he has all the tunes on his labtop.
you can even go into there section and post about your problem.
Old Mar 3, 2007 | 11:25 AM
06blackg85ss's Avatar
Where in NY are you... I'm in NYC and got some good tunes for your setup...
Old Mar 3, 2007 | 11:29 AM
Im upstate NY, about 4-5 hours from NYC Like I said I do have HPTuners but haven't done enough tuning with MAF or this car to feel comfortable tuning it all by myself. I also don't have my wideband hooked up to the Cobalt
Old Mar 3, 2007 | 11:53 AM
DWK5150's Avatar
Sounds to me like your dealer did a reflash and not a relearn and lost intenses flash. Scan the vehicle and look at the tune. Look at the injector flow rate to verify it has been done correctly for the 60s for starters.
Old Mar 3, 2007 | 12:01 PM
im going to be so pissed off if they ended up reflashing the PCM
Old Mar 3, 2007 | 12:12 PM
DWK5150's Avatar
Well it does happen all the time. Contact intense they can email you the file.
Old Mar 3, 2007 | 02:57 PM
thanks DWK i'm going to do that right now...
i've got my hptuners set up now, anyone have a good 2.7" 60lb tune? pleaseee help i'm desperate
Last edited by 607Motorsports; Mar 3, 2007 at 02:57 PM. Reason: Automerged Doublepost
Old Mar 3, 2007 | 04:55 PM
gotcha man.... let me know how it goes
Old Mar 4, 2007 | 02:08 AM
2K5SS/SC?'s Avatar
Shortbus might have something decent for you to take a look at as well. I'd PM him and TAG as well. TAG's tunes are great from what I've seen.
Old Mar 5, 2007 | 10:29 AM
SO... any feedback man... let me know if you had any issues, or at least send me a log file from some test runs.
Old Mar 5, 2007 | 10:50 AM
Hey man, I didn't get a chance to really test things out much yesterday, I did run a couple logs and had no knock retard though I hope to get some logs in tonight and i'll send you the files to take a look at. The car idles and runs like stock right now though
The only issue I need to get figured out now is this damn screeching belt. It honestly doesn't sound like it's coming from the s/c unit at all, kinda sounds like its lower. The belt definately could be a bit tighter in my opinion but I don't seem to be losing much if any boost, it's pushing around 18-19psi.
Old Mar 5, 2007 | 11:04 AM
HMM,.,, def double check to make sure the belt is aligned properly.. might be off a rib on the a/c conp pulley, or the crank pulley. def get under the car and take a look to make sure since it is difficult to see from up top.
Glad to hear it's running good..
if you do get a chance e-mail me a log and I'll see if anything needs to be changed.
Old Mar 5, 2007 | 11:08 AM
Thanks a ton man, you saved me I'll jack the car up when i'm home from work tonight and make sure everything is lined up properly then I'll definately get a few logs tonight or tomorrow and send them your way. Unfortunately they won't have AFR on them as I don't have my wideband hooked up to the Cobalt
Old Mar 5, 2007 | 11:14 AM
good enough, if you need I have a good config file you can use so I can read your logs right has pretty much everything you need to monitor so I can tell what the car is doing.
Old Mar 5, 2007 | 11:33 AM
Actually that would be great, the config file I was using was the one for my cavalier so i'm sure they are other parameters I need. If you wanna send that to me it would be great, thanks man
Old Mar 5, 2007 | 11:35 AM
I'll shoot that over to you tonight when I get home from work. has the correct IDC setup and whatnot. Which wideband do you have? I have a config for the LC1 or the AEM.. l
Old Mar 5, 2007 | 11:39 AM
The wideband i have on my Cavalier is the Innovate LM1 handheld. I actually bought it because of the portability. I haven't had a chance to weld in a bung in the Cobalt exhaust yet though so I was planning on doing that in the spring.
Old Mar 6, 2007 | 03:07 PM
Sorry for not getting you those logs last night, we had some snow here and I really didn't feel safe blasting down the roads at 100+mph lol. Can you send me those config files for the logs though when you get a chance? Thanks man
Old Mar 6, 2007 | 03:18 PM
Yeah man... sorry about last night... had some "issues"
send me a pm tonight to remind me...
found out a friend of mine died in a car accident last night
Old Mar 6, 2007 | 04:13 PM
wow man realllllly sorry no rush or anything on this, I know how rough things can be...
Old Mar 6, 2007 | 04:23 PM
eh... **** happens man... thats just the way it is... sucks but what can ya do..
I'll be home anyway tonight so I"ll get this taken care of since I won't really have much else to do.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
