Negative advance at idle / jumpy idle
Old Jan 29, 2014 | 12:53 AM
100% METH's Avatar
10.5:1
2.0
zzp stage 3 cams
tvs
stock throttle body
80s
idle jumps a little at temp with the maf within 5%.
also timing hits -4 - 0 when idle smooths out.
playing with the scaler 2750-2950, over/under speed tables... it smooths out for a sec holds 16* advance, but keeps falling back into negative advance.
Old Feb 3, 2014 | 09:16 AM
noorj's Avatar
small vac leak?
Old Feb 4, 2014 | 01:49 PM
jp1600's Avatar
uh oh, not this again. You already try messing with your idle tables Im assuming?
On a mechanical side, I have had something similar happen when my injectors were stuck open, always something to check, but unlikely
Old Feb 4, 2014 | 03:41 PM
mrbelvedere's Avatar
its either a vacuum leak or its in the tune do a boost leak test i had the same problems on zzp cams as well
Old Feb 22, 2014 | 11:08 PM
ThexGovenor's Avatar
try the under/overspeed tables from HPT forums?
Old Feb 23, 2014 | 01:27 PM
100% METH's Avatar
I got it
these cams don't like to idle in positive advance below 1100 rpm.
messed with the scaler and min/max settings.
holds a steady idle now at 10* base idle
Old Feb 23, 2014 | 02:46 PM
Glad to hear.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
