p0069 help!
well just got the car back together with new motor trans and clutch. as soon as i got it started and running i went for a test spin and as soon as i hit boost it went into reduced engine power . so i finally got it home and scanned it with hpt. there was about 7 cells in the dtc. i cleared them and it keeps throwing the p0069 though. anyone ever had this problem and if so what can i do to fix it.
thanks
jimbo
thanks
jimbo
inspect both supercharger sensors and look for any damage
skip sensor or baro sensor
if no physical damage is pressent check resistance. both sensors should be at 5 ohms
other than that you would have to check the pcm for 5 ohms to the sensors
if nothing there you need a tech 2 to check the parimeters of the sensors
sensor 1 and sensor 2 are the ones you need to look at
