Please Look Over My Tune
Old Apr 22, 2007 | 07:32 PM
BlackSS/SC's Avatar
Well I've been playing around with my tune and I think I have it pretty good. I just want it looked over to make sure. My issue is the COT when in WOT. I am commanding 11.8 @ WOT. When I did the car in OL I had the a/f ratio perfect at WOT and cruise. Now I re-enabled everything and when I go WOT now it commands something in the 10s becasue of COT. So how important is COT? I have no cat now but the car is way too loud so I'm putting a Magnaflow hiflow on tommorow. If I disable COT will it kill the cat really fast? Or is there a way I can make COT not come on during WOT?
Here's this link to click
log - http://www.hptuners.com/forum/attach...8&d=1177275536
tune - http://www.hptuners.com/forum/attach...9&d=1177275576
Old Apr 23, 2007 | 03:26 PM
BlackSS/SC's Avatar
anyone????
Old Apr 23, 2007 | 09:00 PM
BlackSS/SC's Avatar
Oh I tuned the maf and ve with my wideband logging it. I have the pro version of HP Tuners and my wideband is hooked up to it. You just must not be able to see it without my config file. I'll post a link to it.
Your right, I spent about two weeks in the evenings and on the weekends getting everything smooth. About the timing, I seem to get knock very easy. I run 92 octane and my IATs never go over 150 and it's pretty cool here in northern Albeta still too. I don't understand it. Always had a problem with it. I'm only getting about 16lbs of boost max, I'm 2185 feet above sea level here so I think that's why my boost is low.
Here's the link to my log so you can see my wideband, like I said, when I was tuning it with everthing disabled my commanded PE afr was 11.8 and the car usually ran around 11.5-11.9. Now that COT is on it runs in the 10s.
http://www.hptuners.com/forum/attach...8&d=1177376306
Old Apr 24, 2007 | 10:08 AM
BlackSS/SC's Avatar
Originally Posted by denny
I totaly forgot I needed your config..lol. Its all good I can see your commanded and real AFR are almost Dead on. . Try just for fun to zero out the AFR gas correction and see if you still get knock.
I noticed that your car richens up at almost from 4800rpm and up I would lean it out from 4800rpm to redline with the PE table and disable COT. Thats what I would do.
First I'll disable COT and then my a/f curve should be good. I just had a Magnaflow highflow converter put on it yesterday and they put my wideband sensor behind the cat even I told him to put it in front. I'll have to get that switched around I guess.
Old Apr 24, 2007 | 04:41 PM
Ljavy17's Avatar
subscribed, this is gonna help me find out why my car will not lean out after 6k after I installed the meth. Even after leanning out by .30 in the PE table.
Old Apr 24, 2007 | 04:47 PM
YellowLT's Avatar
Im learning this tuning thing. Whats Cot and the PE table? I follow everything else but that.
Old Apr 24, 2007 | 05:16 PM
BlackSS/SC's Avatar
hey Denny, in my tune when I disabled COT the A/f ratio stayed 11.8. Weird that my tune on your car is different!@
Old Apr 24, 2007 | 05:22 PM
BlackSS/SC's Avatar
Do you mean when I'm WOT? Cuz that's only where I see knock mostly. Ya I have a status bit for COT and it turns on at WOT and keeps commanding a richer afr as it goes lol
Old Apr 25, 2007 | 10:42 AM
Ljavy17's Avatar
I just thought of something, Im gonna see where my cylinder Protection is, It could be that!
Old Apr 25, 2007 | 10:52 AM
YellowLT's Avatar
Could someone help me out? What's PE and COT??? I'm trying to learn this stuff.
Old Apr 25, 2007 | 10:53 AM
BlackSS/SC's Avatar
PE is Power Enrichment which is when you got WOT, and COT is Cat Overtemp Protechtion
Old Apr 25, 2007 | 12:40 PM
YellowLT's Avatar
Thanks
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
