put 60lb injectors in the car.
I put the 60 lb injectors in the car and have a few tuning questions.Do I just rescale the
the flow rates map per injector flow using math ie a ratio of my stock 34 lb injectors to the 60 then multiply it by the value on the table..Then rescale the maf table. I have a wideband and am running a 2.5" pulley.Also will ve tuning be needed or will this be enough.
Thanks,
Thanks,
You'll need to rescale the Injector Flow Rate table. However you'll find out that it maxes after a certain point. You'll have to rewrite the VE and MAF to make up for the extra fuel that the PCM doesn't account for.
Yea I have hp tuners. I wanted to get the car dialed in now.I am running a 2.5 pulley and zzp header and dp gmpp cat back and opend factory air box.
I got one tune form wopontour but he is never around to answer any questions he is super busy all the time.
email address lucyandchris@shaw.ca
Thanks guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
