Stage 2 pulley !
Old Oct 17, 2008 | 11:59 PM
B00MER's Avatar
Stage 2 pulley !
Hi, i want to know if i can only change my stock one with the stage 2 pulley whitout doing anything else ..
If yes, what would be the advantage and disadventage of doing this ?
Old Oct 18, 2008 | 12:03 AM
KillerBee's Avatar
You would need the bigger injectors or you would lean out fast which aint good for your pistons.
Old Oct 18, 2008 | 08:41 AM
B00MER's Avatar
damn lol
So which one should i need whitout changing anything else ?
the 3.1 ?
Old Oct 18, 2008 | 09:24 AM
Snakes709's Avatar
not 100% on this but i think you can go 3.1 without new injectors, iiunno if u have to go to 42lbs...not sure...not recommend...but hey what would i know...im driving on a 2.8 pulley with stock injectors cuz the company didnt send me a harness or clips so i cant hook my 60lb's up.
Old Oct 18, 2008 | 09:35 AM
B00MER's Avatar
ok, so the 3.1 is the stage 1 pulley right ?
What will i gain ? extra power at start i guess ? Because injectors are only good at higher speed..
Do i have to change the hub as well . or only the pulley should do ?
Thanks
Old Oct 18, 2008 | 11:26 AM
KillerBee's Avatar
Thanks
Yeah you would have to change the hub but honestly to get the full hp amount with that pully you should run 42lb injectors if i am not mistaking the stage 2 pully is a 3.09
Old Oct 18, 2008 | 07:58 PM
ralliartist's Avatar
stage 2 is 3.06, before you put a pulley on, you should upgrade to 42lb injectors and get custom tuned.
Old Oct 18, 2008 | 11:40 PM
B00MER's Avatar
damn lol
theres no way i can add up extra power without costing lots $$ :P
Oh and by the way, i was mistaken in my post.. i meant stage 1 pulley which is 2.9 i think ..
Lets try again, if i change my stock one with the 2.9" do i still have to change hub and injectors ?
I want a little more power, but i dont wanna spend hundred and hundred of dollars on that.. not that im poor, but i have other objective !
Old Oct 18, 2008 | 11:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you gotta pay to play
Old Oct 18, 2008 | 11:45 PM
KillerBee's Avatar
damn lol
Yes,
If you change your pully at all you should change your injectors. The small pully the more air and your stock injectors can not push the fuel needed for the smaller pully. Here is what most people suggest.
42lb injectors pully size 2.8+ with a good tune
any pully smaller then 2.8 you should get 60lb injectors.
You can use 60lb injectors wtih 3.1 to a 2.6 some do 2.5 but you will need a lot of cooling mods and a good tune. Stage 2 kit is gunna be the cheapest for you. Unless someone can tune you for free or real cheap.
Old Oct 18, 2008 | 11:50 PM
PinaSS's Avatar
I wouldnt recommend this at all u would be gaining min to no gains at all. You be maxing out ur injectors and plus you would probably have to get a stage 2 belt.
exactly no tune and no injectors no play. its going to cost you for some hp.
Old Oct 19, 2008 | 12:03 AM
B00MER's Avatar
well, i guess i will have to leave it that way for now :|
Old Oct 19, 2008 | 12:07 AM
KillerBee's Avatar
You can do air box mod for more sound or you can get solid mounts that always helps.
Old Oct 19, 2008 | 12:15 AM
B00MER's Avatar
i might try to find an used injen CAI , hard to find u will say , i know lol
Whats that solid mounts ? What does it do ? and about how much ?
Old Oct 19, 2008 | 12:19 AM
KillerBee's Avatar
Well solid tranny mounts at TTR cost about 60-70 bucks and the motor mount costs about 200 and some. But if you get them together i think you get a deal you should PM Aaron at TTR he can hook you up. The mounts are used to stop wheel hop and some what feels like more hp to the ground. But you have to deal with vibes in the car. And i am sure you can find a used CAI on here look through the classifieds i think there are a couple for sale.
Old Oct 19, 2008 | 12:25 AM
B00MER's Avatar
ahh, not bad thanks
Old Oct 19, 2008 | 12:26 AM
KillerBee's Avatar
ahh, not bad thanks
not a problem be sure to send Aaron a pm for the best deal.
stealthy1ss's Avatar
Originally Posted by KillerBee
Yes,
I wouldn't recommend 42's with a 2.8. I am running a 2.9 on 42's and they are pretty much maxed out. Can you say 91% IDC's @ 7000 and some change. Don't want to have your injectors go static.
To the OP, you could change anything you want on your car just remember that things might not last very long. When ever you change pulleys/injectors, things of that nature it is a must to get tuned for those modifications.
Old Oct 19, 2008 | 12:29 AM
KillerBee's Avatar
The only reason why i said 2.8 with 42s is cause some people do run them and run them fine. I would not do it myself.
Old Oct 19, 2008 | 12:33 AM
Not trying to be an ass or anything but my advise to you would to do some research on this site and see how certain modifications work out for others. There is a lot of material that you could educate yourself with on here.
Old Oct 19, 2008 | 12:38 AM
Perfect.disguise's Avatar
You will need a diff hub when you change pulleys.
BTW.. "(0-60 - 2.209)" Your isn't 0-60 is 2.2 thats how long it takes you to go 60'.
Old Oct 19, 2008 | 12:43 AM
You don't necessarily need a hub to change pulleys. Some pulleys are press ons just like the stock ones. The reason why most people buy hubs is so that they can swap out pulleys fast and easily.
Old Oct 19, 2008 | 01:11 AM
We both know considering he want's a Stage 2 pulley that he isn't taking about another press on.That I can remember I have only seen diff size press on's at one site and if I recall the smallest I saw was ~3.1. It's been awhile since I saw it so...
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
