Timing
Timing
Could someone give a quick explanation on how to change the timing in the big table? I mean there is a ton of numbers in there, so I guess I need to figure out where to add or take away timing in accordance with the cylinder pressures, but I don't quite undestand how to figure the cylinder pressure deal out. I have a real good understanding on the fuel now, but that timing table has me all sorts of confused now.
I know I'm a NOOB at tuning, but very interested and willing to learn!
the more g/cl the more map pressure and lower timing. theres high octance for hp and low octane for safety with knock etc. you advance/add degrees for hp and torque and decrease to reduce knock and better emissions etc. in the cobalt the low octane is very generous adding to the low octane by averaging is your best bet.
Also make sure u are logging the right knock total retard and etc for throttle not tps. thatll get you for messing with PE. have fun.
Ok I understand that, but if I datalog will it show me where I need to make those changes. I really need to read up on datalogging as I still haven't done that yet. I tuned today on the street with two of my buddies starring at the wideband while I drove and tried to watch as well.
