tune causing wastegate not to open after 24PSI
Old Mar 10, 2014 | 01:07 PM
hucks1987's Avatar
Hey guys,
Quick question, I have the Hahn 20G and was tuned for 24PSI using the stock boost controller, I have now added a ZZP manifold and Tial 38MM WG and a Hallman BC. But for whatever reason, If I turn the boost contoller to anything higher then 24, my wastegate wont open, I think i have a 20-22Lb spring in the WG itself.
So because i was tuned using the stock Boost controller, is there something in the tune that will cause it not to open? something that will limit it to only 24PSI?
Old Mar 10, 2014 | 01:41 PM
LNFTX's Avatar
Originally Posted by hucks1987
Hey guys,
You might read thru dartsi bnr thread I think at one point he had nearly the same issue
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/bnr-losing-boost-top-end-274214/
Old Apr 9, 2014 | 01:02 PM
hucks1987's Avatar
Yea, It was the tune, My setting with the stock boost controller was set at 24, so thats as far as it would go
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
