Tune over Trifecta?
Tune over Trifecta?
If one were to acquire HP Tuners....and read the VCM with a Trifecta tune.....could one then save that as a base tune and tweak accordingly? Or does one have to upload a tune from the repository and start anew? I have a pretty dialed in Trifecta tune and there r some small tweaks I would like to make as well as nopt be dependent on anyone else in the future for further mods.
TIA
edit: for info.....the "stock" tune that was flashed over to begin with was a hp tuners setup......so i tuned over a hpt file with trifecta.
TIA
Nope, Trifecta writes the tune, lets you flash it, log & send results, & tweak, reload ect.
If you have an LNF, TF has a layer tune that can be HPTuned on top of.
Edit... I see you have an LSJ, not sure if Vince has a layer for that one.
I would flash your stock file back and then tune from scratch with HPTuners.
when i had trifecta to begin with.... the car was already tuned with hpt. i got trifecta. all the old files (trifecta) are on a backup laptop. so i still have them.
i do not have any cables to speak of yet....hoping to pick up hp tuners within the week and this is the onl catch.
can i flash a stock tune to the pcm...full rewrite.....then tune or flash over that? using the hp cables? or am i forced to use the trifecta stuff and somehow obtain a cable and software to flash the "stock hpt" file back?
thanks!
thanks!
