Tuning for MPG
Old Feb 14, 2008 | 10:01 AM
cobaltBlackss's Avatar
Tuning for MPG
I'm going on a long road trip soon and I'm wondering if there is any easy way to tune for better MPG. Would it be a simple as changing my AFR?
Old Feb 14, 2008 | 11:14 AM
lsjwannabe's Avatar
lean out your cruising afr a little can help
Old Feb 14, 2008 | 11:58 AM
I'm assuming i do this by changing the stoich #. How far is safe?
Old Feb 14, 2008 | 12:00 PM
firestorm's Avatar
changing the stoich is a tad risky. everything is multiplied off that. i suppose you can iff you logged all the way with your trusty wideband.
Old Feb 14, 2008 | 12:01 PM
lsjwannabe's Avatar
15.4~15.6 is fine
Old Feb 14, 2008 | 12:03 PM
firestorm's Avatar
fine if you stay out of WOT, perhaps.
Old Feb 14, 2008 | 01:22 PM
Rippin07's Avatar
You can command your afr to be leaner at cruise and make an area or block of cells for highway cruising. You can command a leaner afr for cruising as it is load based and can keep your WOT afr.
Old Feb 14, 2008 | 01:25 PM
Sharkey's Avatar
cruising at up to 17:1 is fine, i did that in my last car. basicly you just lean it out till it starts bogging down then richen it up half a point. a lot of people beleive this can hurt a motor, but this is at light loads, you will not do any damage.
Old Feb 14, 2008 | 02:12 PM
Has anyone done this on their SS/SC?
Old Feb 15, 2008 | 08:57 AM
CSM Huber's Avatar
Open the gap on your spark plugs 5 thousandths.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
