tuning thread
Here's a question that has been pondering in my brain for awhile. With an aftermarket intake you're obviously increasing airflow into the engine (supposedly), in doing so would there be any changes that would further increase the potential gains from one?
heres a ? for all you turbo guys (ik ur out there paul, area, 06black) what exactly is the difference b/w a 2 bar system vs 3 bar system and also what are the benifits on our car for the fuel return system ve returnless system
ok this is the only decent scan i've got right now.
as you can see i'm getting a lot of kr in pe mode.
how do i fix this?
from what i have figured i need to adjust the main spark advance tables. but what do i adjust on there to get this fixed?
thanks in advance area, i'm learning as i go.
btw i'm running a 2.7 60's and some cooling mods. i only have access to shitty 91 octane california gas.
EDIT: can someone send me a config that covers more paramaters such as comanded afr, actual afr
how do i fix this?
2.7in pulley, 60lb injectors, K&N intake, magnaflow catback, fluttering idle which pisses me off. Can't seem to shake it no matter how I adjust the spark/fuel tables.
Confirmed no vaccum leak and even went to stock airbox. nothing. unsure if the problem relates to NGK plugs but they are gapped to .35
Rent me! per hour
idle is either the adder tables in the fuel side, or a fucked maf.
jimbo. way too much timing. pull about 8 degree's out of it from g/cyl .94 on up to 1.36. from rpm 2800 or so to 7464
i love learning how to tune my car
well idi some logging and i need to adjust the tune a bit it's a little rich running 10.9's up top. as soon as i get the fine tuning worked out i'll e-mail it. but if he meets up with me, i can flash it for free i have all 06's unlocked.
