where to begin tuning the 2.4 for boost
ok well ive began making up a kit for the 2.4 for a custom turbo setup...and i have an idea of most of the parts i will be using....the major question here that will determine wether or not i go on with this project is the tuning....i dont know much about tuning...so where the hell do i begin?....im not saying please tell me exactly how to do it...im just trying to figure what to to do and where to begin.....lets make this an informative thread that will hopefully help alot of people out...including myself
i have...he gave me a few pointers that im following up on but i still want to learn more about tuning for boost...like the basics...where to begin and stuff like that
i was reading and i saw a couple of things....would i have to fake a 2bar map?...i saw that somewhere but i cant remeber where
ok well my plans are to push about 350hp roughly out of this turbo setup....so i begin with dynamic airflow...what does disabling this accomplish?.....then i move on to the injectors....which im feeling maybe 42lb injectors or something of the sort....the wideband i already know about....and what does disabling torque management accomplish?
would i benefit to shut the ve tables off and force the comp. to use maf/map?
i havent bought hptuners yet...im just trying to decide wether or not to buy hptuners or find someone with it to tune my car for boost....if it is easy enough i will just buy the hptuners myself and do the tuning myself....just trying to get an idea of what im getting into before i actually get into it
are you yourself planning on boosting you ion?j/c.....as to what witt said...thats what ive been told before so it must work...it would be nice if i could find something that would take this more in depth(shutting off VE)
If you had a J-body for example that is MAP based (Alpha-N), then this would be something you would attempt to do.
You wouldn't be able to fake a 2 bar because your comptuer is MAF based meaning it doesn't calculate fuel maps according to manifold pressure like a MAP based computer system would. You calculate fuel tables according to the amount of air that is being drawn into the engine or should I say pass the wire on the MAF. According to the temperature of the wire, it will send upwards of 5 volts to the computer to express how much air is coming through.
