War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
Cobalt vs Pullied Cobra
Old Sep 7, 2010 | 03:42 AM
  #51
elite_Cyborg's Avatar
Self It is a spec 3+ i was just blowing the tires off. The cobra hit the limiter, i thought mine was acting up so i got out of it when this happened. It was a 40 roll.
And the race with the ta was on a way worse tune than with the cobra.
Motor is fully built valve train and all + some port work. No numbers as it was just finished a week ago. Motor had 700 miles on the race with the cobra about 500 on the one with the Ta
Oh ya, and the T/a put a car and a half on the cobra from 40-120.
Old Sep 7, 2010 | 06:53 AM
  #52
selfinfliction's Avatar
Originally Posted by Area47
keep defending the cobra. you won't win this one.
yeah cause there's a few of us that did the same thing.... roughly same results as when i raced one when i stretched the head bolts, except he did not pull on me that hard (when it looked like he sprayed against cyborg)
Old Sep 7, 2010 | 06:54 AM
  #53
oh no kidding i could hear the revs going up but no tires spinning, and form your initial video it looked like the revs shot up but the speedo was slow to turn over
Old Sep 7, 2010 | 09:42 AM
  #54
Shibito's Avatar
Originally Posted by cakeeater
Details? I just find it staggering that he posts about getting pulled by an n/a TA from a 40 roll and it's impossible that this cobra wasn't on the juice when he got the jump on the cobalt's shift and the balt bounced off the limiter a shift later. A little inconsistency imo. What did the TA have a flux capacitor?
At least not everyone in here is being a Balt fanboi, thank you.
Add a couple pounds of boost OP and it would be a great race.
Old Sep 7, 2010 | 09:44 AM
  #55
Shibito's Avatar
Thank you for finally posting up that you were spinning. I figured since no one mentioned any spinning previously that you hooked just fine.
Old Sep 7, 2010 | 09:52 AM
  #56
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by selfinfliction
let me play the dumby role here like they did in my thread. that was fake! there's no way you could hang with a modded cobra! your car is t3h slow!
silly forumers don't understand how fast these turbo lsj'a are from a roll.
anyways, are you still running the stock clutch, it sounds like it's slipping like a ****. and the cobra did look like he sprayed right before you let off, he probably felt bad for not being able to make your little cobalt look bad and had to crack the bottle to prove self worth
no its just your turbo LSJ thats slow.
Old Sep 7, 2010 | 10:57 AM
  #57
yea, i can hear the tires spinning so i know the clutch isn't slipping, idk maybe my speedo is getting old and can't keep up. lol
Old Sep 7, 2010 | 11:10 AM
  #58
Area47's Avatar
Rent me! per hour
So Area, you're saying the cobra must be spraying to pull the OP? How much power is the OP laying down and has he been to the track or is this just more speculation like the last time we talked about yours and elite's cars? A 75 shot + 2.8 cobra is a mid-high 12X trap car, just to clarify.
if you want the truth about it. the owner of the cobra WAS spraying.
Old Sep 7, 2010 | 11:13 AM
  #59
Shibito's Avatar
That must be it
Area, even if he did spray, it doesn't sway the result of the race.
Old Sep 7, 2010 | 11:14 AM
  #60
Area47's Avatar
Rent me! per hour
he raced the TA when he was on the blower
the cobra race was is the new turbo swap.
venture outside of the kill section once and a while.
Old Sep 7, 2010 | 11:15 AM
  #61
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by Shibito
That must be it
so ~80whp less on the cobra wouldn't have swayed the race?
  #62
Area47's Avatar
Rent me! per hour
That must be it
so he got beat. whoopdidoo
Old Sep 7, 2010 | 11:16 AM
  #63
Shibito's Avatar
LMFAO, you think a 75 shot makes 80whp? Holy **** I want what you're smoking.
It was a 75 shot right? I'm just going off what's been posted.
Old Sep 7, 2010 | 11:18 AM
  #64
Shibito's Avatar
Just saying, I was under the impression you thought the result would have been different.
Old Sep 7, 2010 | 11:20 AM
  #65
I can gurante that the outcome will be different next time we race, unless he jets it up.
Old Sep 7, 2010 | 11:22 AM
  #66
BLAZIN07SS's Avatar
I'm too JDM for you
you realize i have probably run more nitrous than everyone on this forum right? with correct bottle pressures on a supercharged set-up you will gain the amount or a little more than the shot is rated for in whp
Old Sep 7, 2010 | 11:24 AM
  #67
Area47's Avatar
Rent me! per hour
actually yes.
you still have a bit to learn about nitrous there special ed
Old Sep 7, 2010 | 11:25 AM
  #68
BLAZIN07SS's Avatar
I'm too JDM for you
actually yes.
just going off results on the dyno fgt
Old Sep 7, 2010 | 11:30 AM
  #69
Shibito's Avatar
Ya... not on a 4v. I played with the idea but the guy who does my dyno tuning turned me away. A small shot on the Eaton is really only acting as a cooling agent for that blower with a minor increase in power. Not a big difference maker.
Anyways, just go out and do a run without the nitrous with a run on the nitrous right after and post them both up. I see no reason why the Cobra owner shouldn't agree.
Or I can run the OP because if that shot really adds 80whp on top of a well tuned n bolted 2.8'' car he should be about the same power level as me.
Old Sep 7, 2010 | 12:34 PM
  #70
evolve's Avatar
Ive seen Cobras (with Eaton, ported of course) make over 700rwhp with a good shot (~150) of N2O. This is on the stock motor btw...
Old Sep 7, 2010 | 05:00 PM
  #71
cakeeater's Avatar
Directly from the Eltie Cyborg vs TA thread -
Originally Posted by restonSS
this is w your turbo setup?
Yes.
Weird, we must be talking about a different elite cyborg racing a different 6.0l n/a trans am.
Venture outside of la-la land once in a while. How can you claim you know for a fact that the cobra was spraying when you knew for a fact that the blower was on the car when he lost to the TA when in reality, the turbo was on the car? LQ9/L92 camaro's I have seen have been mid 120 trap cars in full street trim other than some meats out back. Not exactly going to blow a way a bolt on termi like evolve's for example. So when elite loses to the TA it's all good, but when he is spinning and loses to the cobra, the cobra must have been spraying? Again, it's a little inconsistent. Sorry, strike that little, it's very inconsistent.
Old Sep 7, 2010 | 05:21 PM
  #72
JHans5774's Avatar
This is turning into another classic bitch fest about how cobra's are the ******* fastest cars in the world thread just like the last one that got shut down. The trans am he raced was when he hadn't fully played with his tune. (Which still has work to do still so the outcome of this race will be very different next time) Both cars are quick but without spray for sure this cobra almost got pulled by a bolt on tuned ss/tc I think elite is a little faster than that.
Old Sep 7, 2010 | 05:26 PM
  #73
cakeeater's Avatar
So you're saying a 75 shot would make a car that "almost" got pulled by a bolt on and tuned ss/tc, pull on elite's car? That's a hell of a 75 shot. Maybe it's a 750 shot. I still think it's a flux capacitor though. I mean damn, if elite's car is only that much quicker than a bolt on/tuned lnf, he wasted a LOT of money right? I'm not saying the cobra definitely didn't spray, but the logic backing the apparently definite truth that he sprayed, is extremely flawed.
Old Sep 7, 2010 | 10:06 PM
  #74
Ive raced the Ta multiple times, One was when i had the blower, it was dead even, but then again his trans was blown during this race and hadn't realized it yet. we raced AGAIN the other night on the new setup. And no i didn't waste any money going turbo.
Anyways, me and the cobra are gonna race again, this time he is putting in 150s
Old Sep 7, 2010 | 10:21 PM
  #75
cakeeater's Avatar
I was being sarcastic about wasting money on the turbo because of the notion, by Jhan, that you got pulled by a car that almost lost to a bolt on ss/tc. Why aren't you guys going to race with the same setup on the cobra?
