HP vs. Trifecta
Nothin Stock
HP vs. Trifecta
HP vs. Trifecta
So a buddy of mine just got a trifecta tune on his 09 t/c....so we did a couple digs....he was tuned at 22psi and my mods are in my signiture...i beat him both times
heres the vids
Fast forward about 30 seconds in im not sure how to edit
Part 1
YouTube - grandamGT1's Channel
Part 2
heres the vids
Part 1
Part 2
Nothin Stock
just trifecta tune at 22psi
Last edited by gotboost?17; Sep 19, 2010 at 09:57 PM. Reason: Automerged Doublepost
Congrats!
Look like you beat him without much trouble
I raced a 20.5 HPT one about a month ago from a roll (i am the camera car...)
http://www.youtube.com/watch?v=YSdLs3i9c4o
i have a trifecta 22 psi tune, had to run from 3rd gear, had no traction in 2nd gear that night with a colder weather (you can hear on the first run... )
Nothin Stock
Congrats!
YouTube - Cobalt SS trifecta 22 psi vs HPT 20.5 psi
Boost is a measure of intake air restriction. His turbo was able to spool more efficiently because of the catless dp and pull in more volume because of the K&N. The added efficiency allows more power to be transfered to the ground. Also as you start to run a turbo out of its sweet spot you reach a point of diminishing returns. The turbo creates more heat and pressure in the exhaust, which takes power away also. If you keep a turbo in the peak of efficiency it works a ton better... case in point, the diesel in my sig. stock only runs 8-12 psi MAX! it just runs out up top.
Common sense for those that don't get it yet
Its not like we were going to cross a line anyway, we floored it about in same time everytime, on the first run im in 2nd gear and he got may be half a car because of the wheelspin i had, you can hear the engine rev near redline, then i hit 3rd and hes behind.
Ill try to make a better one next time
I agree.... digs are not the way to go to show CAR abilities. Driver plays a huge role. The mods are not identical and if you ask me I didn't think the difference in those dig races was all that huge.
If everything was about car ablilities I would drive a lexus, or rather ride in one, that can park and drive itself. If you want to race you have to take the chance of looking like a idiot for not being able to launch. Its one of the reasons to learn how to launch well. If you want to show car abilities do some dyno runs, that would probably be the best way since you don't have to worry about variables, cops, or wrapping your call around a phone pole.
I took others advice and launch at 2,000 rpm and kinda roll into the throttle, but quickly. Seems to work pretty well.
HP vs. Trifecta
heres the vids
Part 1
Part 2
heres the vids
Part 1
Part 2
I'm the one that did the tuning on the HPT one. Stock DAL's, no additional timing, just hand smoothed. .87-.86 lambda throughout and all the right things in all the right places. Also he's at about 19 pounds. Car's got alot more in it.
Related sidenote, the OP can't drive for ****. ^_^ SORRY JARRED BUDDY =D
gotboost?17
yeah trifecta is overated when you have a catless dp and a drop in filter and all the other guy has is a tune not to mention it was from a dig next time let the kappa forums know your mods before you open your mouth
[quote author=pantherqs link=topic=5316.msg73296#msg73296 date=1285033454]
In your opinion, no. In mine, yes. I'll throw a competently hpt tuned lnf against a trifecta tune any day of the week. Key word, competently. The amount of toolsheds running around with HPT nowadays is astounding.
[/quote]
\remeber that lolz il spank your cobalt in my trifecta solstice any day boy
[/quote]
