LS1 killing
duh with over 10 years of aftermarket support, theres no doubt that it takes less money to mod and make it faster. but just admit the fact that now days a tuned 4 banger can beat a so call glorious motor without any problem...that was back in the day that they were all that. now they have to do more mods etc to be able to keep up with 4 bangers making same or more hp numbers than all if not most older 8 cylinders. oh yea and with 4 cylinders less and much more efficiently...
I didn't see anything in the original vid to say the guy did anything else that would warrant a higher stall. The LS has a flat torque curve, and there's no benefit to putting a higher stall on the car without the need to, since it'd not put a mildly modded LS any further into its sweet spot. Does he buzz it to 7k with that setup? I doubt it! He'd need to get more radical to benefit from that high of a stall, and I think his mods are backwards, making him actually a weaker player - that's all I'm sayin'!
My point was that there is benefit to putting a stall in a basically stock LS1; my point was not that he should go with a higher stall, as you interpreted.
That car is now a heads/cam car though.
Hey now, I thought he wanted to go from a little higher speed and by the time I realized we were going from 20, he was already honking it off so I just said eff it, this Cobalt has a pretty broad powerband, I'll just go.
On the flip side - LS1 engines are actually old technology. It does say something that the first gen LS series is still this dangerous. It credits the naturally aspirated LS engine that it can run with purpose built turbo's making 20-plus psi of boost with some fairly generic upgrades, even if the cylinder count is different. I know my first gen small block couldn't make that same claim without race heads, a radical cam, and barely streetable manners.
TeQTonySunshine
Aug 28, 2015 08:57 PM
