War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
purplehaze03 vs. hyundai genesis V6
Old Dec 28, 2009 | 09:11 AM
  #76
Mike09SS's Avatar
no i agree with you on how dynos are just numbers, and are not real. track times will tell it all. What i do know is that his baseline run was around 252hp? or possibly 262. so the dyno does read a little happy. But he did gain 100+whp, and obviously over 100+wtq, so ive got respect for the mans abilities. hopefully his track numbers prove it. if he ever goes that is.
Old Jan 4, 2010 | 07:10 PM
  #77
Terminator2's Avatar
Originally Posted by Maxim_X
LOLer. First of you don't know anything unless you dyno it. You think you have 400 tq.
But, let me break it down for you. Torque is a useless number. All torque shows is horsepower early in the RPM's. Your peak torque has no relevance to power made during a pull high in the RPM's. SO, spout off about your high torque all you want and geusse to what you car can run and trap. But, I know what my car has for power and what it does on the track as it sits @ 22psi. And I guarantee to you it would make your's look foolish when that tiny snail runs out of steam and I make real power up to 7400 rpm's.
Again, I know what it takes to go that fast and I doubt that your car does it.
That is ok I make peak torque at 3500 rpms. I can short shift all day long. Torque is useless number? Are you retarded? How do you think they calculate horsepower? I have a huge amount of area under the curve from 3000-6600 rpms. It takes big torque to make big hp unless you rev to 10,000 rpms. Yeah my car is slow, it runs 60-100 mph in 4.5 seconds consistantly. You have loads of lag and do not make peak torque or even spool up fully until a long while after I do I. Big lowend and midrange torque gets you moving
Originally Posted by SLoW SHO
Which means you're making way less POWER. You know what it can do but you haven't been to the track? You're a salesman thats all you are, and everything I've ever learned about salesmen tells me they don't know **** about what reality is. You're conforming quite nicely to that pattern.
"It traps 117-118"
BS, show some slips.
"Uhhh, I know what it can do..."
Way less power huh. I will take my lowend and midrange torque advantage over his lag and weak lowend and midrange torque. I dont need to rev that high. BTW StageZero has a GT2876 swapped LNF Cobalt that makes 370 whp 350 wrtq and it runs 5.2 seconds from 60-100 mph. My car using the same scanner and method runs 4.4-4.6 seconds from 60-100 mph but hey my car is slow remember.
Originally Posted by cakeeater
I'm not saying he wouldn't. It's unlikely, not impossible, but the fact that he claims it without any logic or facts to back it up, destroys his credibility. Good tuning comes from long term experience and peak dyno numbers almost never show who really has the best tune. Every one of the cars he tunes could crack a ring land in a month and trap lower than somebody else's tune or it could be the best, but dyno numbers will have nothing to do with that. Dynos are for advertising to newbies. Tracks are for testing.
That was a street tune that I dynoed. I have 15K miles of street tuning on my car. I change things almost daily. That quote in my sig is from the owner of one of the last cars I tuned. He has owned several very fast cars including a 530 whp Terminator Cobra and a Evo IX on 33 psi and meth. He says in his own words that his car pulls harder than his Evo did on 33 psi with meth. He easily beats his friends tuned SRT8 Jeep that traps 110 (he put 2 buses on him from 40-120) and he put and held two cars on his friend 360 whp stage 3 SRT 4 from 40-125. If you do not believe me you can always ask him. My secret is not big numbers it is really area under the curve.
Last edited by Terminator2; Jan 4, 2010 at 07:10 PM. Reason: Automerged Doublepost
Old Jan 4, 2010 | 07:21 PM
  #78
cakeeater's Avatar
It feels quicker when you make more torque, it doesn't necessarily make the car quicker. Like I said, power is less than half of the battle. The only way to tell who is a good tuner is by looking at long term reliability and track results. I've done dyno tunes where I couldn't pull any bit higher numbers, then gone and gained 2-3mph over that dyno tune with test and tune at the strip. The dyno is a tool, not a system for comparison. If a butt and dynojet dyno's are the only thing to support your tuning, I suggest you drop down on the cockiness. I'm not saying your tunes aren't good, because really I have no idea they could be great, but you can't claim superiority by butt dynos.
Old Jan 4, 2010 | 07:49 PM
  #79
No butt dyno, I data log and record acceleration times on the same stretch of hwy with my scanner. I generally use 60-100 times as a bench mark because it is a full 3rd gear pull. No shifting, traction, or driver skill involved. I like to eliminate as many variables as possible. Stock, most LNF turbo Cobalts take 8.5-10 seconds to go from 60-100. Big disparity because sometimes there are 3 people in the car, but sometimes it I am by myself. With just tuning using the same exact method they normally run 5.2-6.0 seconds from 60-100 mph again depending on how many of us there are in the car. Either way you slice it cutting off an average of 4 seconds off your 60-100 acceleration time is a big gain. It would be even bigger if the factory boost solenoid was not so weak. I have a regulator on the boost reference in to the boost solenoid on mine so I can run 24-26 psi instead of being limited to 20-22 psi. No issues with my car so far, but I do wish GM would have put forged pistons in this motor instead of cast pistons.
Old Jan 4, 2010 | 08:10 PM
  #80
Maxim_X's Avatar
Look here mother ******. If you knew half of what you thought you did you would know that it's the torque calculated not the horsepower. How do you think a dyno get HP reading with no rpm pickup? Who the **** do you think you are? Call me retarded? You dyno number nut hugging ****!
Right there you just proved how completely full of **** you are. Your stupid ******* data logs are complete bullshit. Your stupid quotes from, "customers" and butt dyno comparisons further prove how much crap you talk.
Get some track times or shut the **** up.
Then take your 400tq vrs my 330 and get a jump because you won't be in front for long.
Old Jan 4, 2010 | 11:29 PM
  #81
SLoW SHO's Avatar
x2
Terminator is officially retarded (as if we didn't already know).
Powahhhhhhhhhhhh > TQ!
400tq @ 3500rpm < 330tq @ 5000rpm. Not to mention the added benefits of being able to stay in gear longer!
You can see how naive Cobalt owners would jump all over the chance of the almighty terminator tune. I mean, some guys cousins uncles brother who once had a 870whp Cobra and said his tune was good!
Reminds me of those direct to market adds on tv, BUY NOW!!!
Old Jan 4, 2010 | 11:33 PM
  #82
Mike09SS's Avatar
x2
its funny you would bold that statement. you claim to be in the 11's with your gto but have 0 proof. funny
Old Jan 4, 2010 | 11:35 PM
  #83
SLoW SHO's Avatar
This isn't even about my car, I'm not here trying to sell my methods, ****, if anything I'm trying to keep them a secret! I get zero gain from any claim, while Term here sells tunes on the basis that it is ultra-l33t 400tq @ 2.4rpms and 118mph traps!
Old Jan 4, 2010 | 11:43 PM
  #84
Mike09SS's Avatar
i dont see whats so hard to believe about a car that weighs 2900 lbs making 363whp running in the upper teens. granted he has no times, but this guy has been one of the most helpful and knowledgeable members on this board along with always being a nice guy. dont be a hypocrit, you made claims of your own with less proof than terminator, and alot less believable to.
if you expect people to believe your tune only with headers gto ran 11's, i wouldnt be doubting anything.
Old Jan 4, 2010 | 11:49 PM
  #85
SLoW SHO's Avatar
It's the simple-minded thinking that'll get you into trouble.
Old Jan 5, 2010 | 12:03 AM
  #86
Kildore's Avatar
Why is it that everyone is fighting? One has to respect the people that have the knowledge and the capabilities to tune cars nowadays.. especially the New LNF with the new bausch computers. Keeping secrets are nice and all, but why not try to help further the development of the aftermarket segment? Terminator and many others are a true true trail blazer for us. I for one dont have the luxury of no warrenty, but will soon be able to enjoy what you all have now. When that time come.. i'll be in hopes of gaining knowledge of proven parts, kits, etc. Furthermore, if i did end up stumbling onto some thing great... i would most certainly share it with others. I dont aim to gain anything by trying to be the best.. and quicker faster than others.. when it comes down to a drivers race.. having a blast with people that share the same ideas of 4cyl cars blowing the doors off of v8's? Thats all the fun righ there. I just want to say thank you all for doing what you do for the love you have in doing it.
Seems kinda cheezy, but felt as though i needed to say something.
Old Jan 5, 2010 | 12:11 AM
  #87
Mike09SS's Avatar
i wudnt say anyones fighting. people just want proof...which is understandable, but at the same time people just shudnt be making claims of what a car can or cant do especially when they have never seen it before. our cars are still relativley new, and tuning has come a long way in the past 6 months. i dont doubt it, but hopefully he can prove it.
Old Jan 5, 2010 | 12:18 AM
  #88
SLoW SHO's Avatar
He can't prove it, because proof would ruin his credibility/business when he traps nowhere near his claim.
Terminator on street tire = high 12's @ ~113-114 on his best day.
Old Jan 5, 2010 | 12:57 AM
  #89
40rty's Avatar
For every guy making tunes etc just take the Google business model maudo
"Don't Be Evil"
It work for them and made billions, so I would suggest the bickering and claims of this and that be put aside and a group or alliance of tuners and tuners themselves share these LITTLE secrets to bring to the cobalt world a good tune that provides good power, reliability and just some ******* fun.
Remember, the people in your ******* market are not all car savy, they just like the fact that the car makes some more power. That alone is exciting and **** to them but they really won't give a **** really about who tuned or anything. Maybe a recommendation and a "Thanks Man" but that's it. Calm down on this power trip of who knows more, straight to arguing and calling names and **** instead of contructively correcting each other. There was one guy on here(matrix something) went ape **** with "****" **** this and **** you and that, chillax.
Its a forum, holy ****. I wish all would just come over and talk about this over some Marry Jane, ****.
(Puts flower in the bore of the gun) LOL LMAO
Old Jan 5, 2010 | 01:07 AM
  #90
CordiaDOHC's Avatar
Im just calling BS on the 40-70 time being less than 2 seconds. Period.
So Terminator let me get this straight... your 400tq beat a 480 tq car and the 480 car also had more hp and stayed in its powerband longer...
You might be in the 3-4 second range for 40-70 but definitely not less than 2 second range!
Now yes granted his are whp ratings. But still even then hes giving up parts of the powerband as well as a good chunk of hp. Yes the porsche weighs more but it has the advantage of better traction a better powerband and more hp still (even using the 15% drivetrain loss formula and its most like around 8-10% in a porsche). Im calling bs on his 2 second time. The rest of the information is up for debate. But if a porsche can do it in 2.5 then I cant see his lnf doing it in less than 2 with less traction and less power.
Old Jan 5, 2010 | 02:06 AM
  #91
cakeeater's Avatar
Originally Posted by maxim_x
look here mother ******. If you knew half of what you thought you did you would know that it's the torque calculated not the horsepower. How do you think a dyno get hp reading with no rpm pickup? Who the **** do you think you are? Call me retarded? You dyno number nut hugging ****!
get some track times or shut the **** up.
then take your 400tq vrs my 330 and get a jump because you won't be in front for long.
lulz.
Old Jan 5, 2010 | 04:35 AM
  #92
40rty's Avatar
I don't know about all you, beat this!!!!!
80,000 TPP, 4 LM2500 Turbines beat that!!!
Tuned at Bath Iron Works Bitches!!!
And if you do pass me, I'll just turn the gun on you and shoot a HE-VT shell and blow you up.
Greetings from the Pacific
Old Jan 5, 2010 | 09:57 AM
  #93
Rodimus_Prime's Avatar
im surprised it was that close
Old Jan 5, 2010 | 11:04 AM
  #94
cakeeater's Avatar
Apparently, I know more than you. If you had any sort of an education you would know that in physics, torque (work) is a measured value. It is used to calcuate power. In this case, HP is calculated using the formula. HP = Torque X RPM / 5252. A dyno does not measure horsepower it measures torque.
Want proof, quoted from this page http://www.revsearch.com/dynamometer...orsepower.html
On modern day dynamometers horsepower is a calculated value. It's important to remember the dyno measures torque and rpm and then from these calculates horsepower. On the dyno it takes more water flow to the water brake to increase the load on the engine being tested. As the test engine's torque rises more water flow is needed. As the test engine's torque drops less water flow is needed. The dyno's water brake does not respond to Horsepower. Major adjustments to water flow are needed as an engine crosses its torque peak but none are needed as it crosses its horsepower peak. In other words the water flow to the brake during a dyno test follows the engines torque curve and not its horsepower curve. Torque is what twists the tire, prop, or pump. Horsepower helps us understand an amount or quantity of torque. (Torque + time and distance)
We see horsepower can be directly measured. However there is a problem directly measuring horsepower of modern day internal combustion engines because they produce rotary motion not linear motion, and unless the engine is geared down, the speed at which they do work (time and distance or RPM) is too great for practical direct measurement of horsepower. It seems logical then that the solution was to directly measure torque (rotational force eventually expressed in pounds at one foot radius) and RPM (time and distance, i.e. distance in circumference at the one foot radius) and from these calculate horsepower. Torque and RPM are easily measured directly. Early dynamometers used a brake device to load the engine. A torque arm was attached to this brake's stator. The brake's rotor was coupled to the engine's crankshaft. A spring scale or other measuring device connected the torque arm to the stationary fixture holding the engine and brake. During a test the brake's application loaded the engine. Torque and engine rpm were observed and recorded.
actually, dynojets and most other chassis dyno's, at least other drum dynamometers measure horsepower and calculate torque. What you quoted is about an engine dyno, which is not what you use. I don't need to go quote some website because I know this is fact, it is physics. the drums on a dynojet have an effective weight of 50 lbs. The computer measures how many revolutions the drum makes in a given amount of time, calculating work from distance (revolutions of the drum of known circumference) and the force required to move that 50 lbs. Once work is found, power=work/time, so it's a simple, direct calculation to get horsepower. Otherwise you would have to rely on optical rpm outputs or the crank sensor which may be inaccurate and would give you a false horsepower reading. Since the required force to rotate the drum is known, getting a more precise reading of horsepower is possible by directly calculating it instead of calculating torque then using the conentional hp=tq*rpm/5252.
Old Jan 5, 2010 | 11:16 AM
  #95
actually, dynojets and most other chassis dyno's, at least other drum dynamometers measure horsepower and calculate torque. What you quoted is about an engine dyno, which is not what you use. I don't need to go quote some website because I know this is fact, it is physics. the drums on a dynojet have an effective weight of 50 lbs. The computer measures how many revolutions the drum makes in a given amount of time, calculating work from distance (revolutions of the drum of known circumference) and the force required to move that 50 lbs. Once work is found, power=work/time, so it's a simple calculation to find horsepower. You are wrong, he is right.
Nevermind apparently I have the engine dyno and chassis dynos confused. I apologize
Old Jan 5, 2010 | 11:18 AM
  #96
cakeeater's Avatar
I just woke up. I'll explain it better in a little, but it's a common misconception, so I don't blame you.
Old Jan 5, 2010 | 11:52 AM
  #97
SLoW SHO's Avatar
Term cant be wrong though!!! He's the l33t tooner!@!!1!!!1!!
  #98
I just woke up. I'll explain it better in a little, but it's a major misconception, so I don't blame you.
Cool. Thanks.
traviskearney
Feb 17, 2006 02:26 PM
Doc
Autocross and Road Racing
Feb 3, 2006 09:44 AM
merlin
Canada
Dec 24, 2005 01:44 AM
