V8 slaughtering
V8 slaughtering
so i was at my local dragstrip tonight.....went against a 5.0L he has gears 3.73's magnaflows cut off part way back or something
and an intake
I have stock..;......
well I think we know who won. 2nd to third with a NLS is awsome. and 3rd gear pulls hard....is very niace
and an intake
Well the 94's were right after the fox bodies....they are some of the slowest stangs in stock form due to the extra weight.
I would like to see you go against a fox body with the 3.73's....might be pretty close if they can drive...with mine, once I swapped the heads, I was in the 12's
and an intake
and an intake
The hot rod article showed that an LSJ with cams, exhaust and an M90 put out 20 less horsepower when swapped to a TVS with the same combo
I raced a friend of mine he has a fox body 5.0 with gears and flowmasters with my sc with 60 miles on the car at the track won by 3 lengths. Now it's a different story now that he has a 347 stroker
Stock shortblock out of a 91 LX. It has run 11.8s on motor at 115.9mph while having a nonlockup AOD. I know what you're saying though...the next time I spray it that could be the last. A few nitrous guys have run in the 9.8-9.9 range without the block splitting...but it's really only a matter of time before it happens.
