The War
You can get blow by signs if you pop the headgasket in the right place too. I take it there wasn't any coolant/oil mayo looking stuff on the dipstick? Might want to do a compression test too, but that will obviously fail, but curious as to how bad.
KR was only 1 or none. AF was on or below 12. It ran great. I think it is those cheap GM pistions because Cam is making around 350HP to the crank. At first I thought it was a head gasket but by the sound of, it seemed like it was firing on 3 cylinders (yes I know it could sound like the with a blown head gasket). Maybe he lost compression in one cylinders is what it seems. We will see.
Yeah no signs of coolant or anything. Then he would be in ****'s creek. It was all oil when we wiped it down to clean it and drive it back home.
Last edited by SwizzDSMSS; Mar 16, 2007 at 03:23 PM. Reason: Automerged Doublepost
Yeah, the highest I saw the AFR during the run was like 11.8-11.9. Also through out the run my KR was at zero exept for a few spikes of .8-1 then back to zero. I'm pretty sure I just over powered the pistons. I mean, I had to puttin at least 320 to the wheels to be able to beat a 298 whp SRT that bad. Just a matter of time I guess...
damn that sucks so bad,what are you gonna do for your daily driver?? and i just ordered my 2.6
, i dont know what to do
another thing what was the temperature when it went
, i dont know what to doanother thing what was the temperature when it went
Last edited by Red2.4SS/SC; Mar 16, 2007 at 04:18 PM. Reason: Automerged Doublepost
damn man... just saw the vid... but it def sounds like the 3 other motors that blew up by me... WRX swap...lol.. thats the best way to describe it.. sorry to see it go down like that.... but at least ya won
Yeah, I'm pretty sure its a ringland. I can't imagine why it would "hole" a piston, I wasn't running too lean and I wasn't getting any knock or very very little. **** man, this sucks monkey nuts!
put all your stock **** back on and go in for warranty
youll have a ported blower thats the only thing i can see being a problem
Last edited by Red2.4SS/SC; Mar 16, 2007 at 04:46 PM. Reason: Automerged Doublepost
Do you plan on at least taking the head off and taking a look anytime soon? My car did exactly the same thing as yours (sounded like it hit the limiter, shot oil, cam/wrx sound idle), but once the head was off, my pistons and cylinder walls were pristine. So I wouldn't get ahead of yourself until you actually look. Compression test would also give you a better idea.
I don't think a compression test would help anything, the compression would be really low for a blown head gasket, ring land, or a burnt valve. So I think I might just take the head off and have a looksy.
pm djt I think him or self infliction from the rl forums might be able to get their hands on em..
I don't know what happened to the Mahle... they used to be for sale on cobaltperformanceparts... but no longer on the site
**** I"ll be running the 9.5:1 diamonds with my turbo build.... don't need high boost... just high airflow (I"ll have cnc'd head, cams, and to be determined turbo) should have some more info tomorrow
damn dude your top end was insane you just kept pulling like a nerd on an asian **** site. sounded like you had a great time you know I like pickin on you so does this mean that instead of now having one of the fastest cobalts in az you now have the slowest? and all in one night? sucks that happened though git r fixed up and then do the twin screw and pwn again ... "you can dew it" -various adam sandler movie characters.
