War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
The War
Old Mar 17, 2007 | 05:11 PM
  #76
BlackSS/SC's Avatar
Hope it doesn't cost ya too much and you don't run into any other damaged things in there. I was thinking though, if you burned a valve how did all the oil get outside of the engine? Wouldn't that just be contained inside the engine and make it run like it is?
Old Mar 17, 2007 | 05:59 PM
  #77
CobaltBurst's Avatar
sucks man.... but grats on taking down the town big dog on your way down lol
Old Mar 17, 2007 | 06:07 PM
  #78
R&C_rallySS's Avatar
Originally Posted by Blown 4-banger
If some of you remeber my thread about racing those SRTs, this is the sequil to that. The fastest SRT out there that night (298 whp) beat me pretty good. I told him I want a rematch with race gas. Well it happened, the result.... his car about 3 car lenths behind mine at 145 mph Tell me how is it possible for my car to put 3 cars on a 298 whp SRT if it has less than 300 whp (according to Ljavy17)? Anywho, my cars prolly got around 100 whp now since I blew the motor while racing the SRT. I hate GM
Oh, heres a video of "The War"
http://videos.streetfire.net/video/6...f300790eea.htm
might still be converting...
Can't blame GM when your running your car like that and putting smaller pullies then stage II.
Well using the process of elimination we've come to the conclusion that I burned a valve. It doesn't over heat, doesn't smoke, and a 4 spark plugs look perfect with no oil on them, but it still only runs on 3 cylinders. Ferria Ti big bore valves HERE I COME! Glad it wasn't a piston... although I'm replaceing those as well.
See ^ was not as bad as you thought. Glad you did not totally blow it.
Very cool vid BTW.
Damn, what is your rev limiter at? You hit it in 4th?....
Who was reving your engine like that afterwards....that could not of been good.
Last edited by R&C_rallySS; Mar 17, 2007 at 06:07 PM. Reason: Automerged Doublepost
Old Mar 17, 2007 | 06:11 PM
  #79
SilverSS/SC's Avatar
Sorry about the luck man . But hey ....once its done and stronger , itll be funner to play with
Old Mar 17, 2007 | 06:20 PM
  #80
cobaltBlackss's Avatar
I'm sorry to hear about this...I had a flashback when I watched the vid
Old Mar 17, 2007 | 11:24 PM
  #81
BlackSS/SC's Avatar
I still don't understand how a burnt valve would cause oil everywheres. Hope it's nothing too big.
Old Mar 17, 2007 | 11:48 PM
  #82
memphisr24's Avatar
I belive he said his dipstick shot out....which is why I belive he lost the oil...
Ehh, i'm going to argue the wrx sound....To me it sounds more like a BPU Supra with a LIL mix of a wrx/wrx sti sound.
But putting that all aside, blown4banger, I look up to you man. You're always helping out people on this board and it just sucks that this happened to you. But in the end, you will get a laugh out of it, and your engine should be 10 times stronger......Now about those 1/4 mile times....lol jk man
Old Mar 18, 2007 | 12:32 AM
  #83
BlackSS/SC's Avatar
Ahh, it all makes sence now.
Old Mar 18, 2007 | 12:34 AM
  #84
8cd03gro's Avatar
seeeecretttttt loooooooooverrrrrrrrs DOOO DOOO DOOO
Old Mar 18, 2007 | 12:46 AM
  #85
memphisr24's Avatar
Hells yeah, leave us lovers alone! lol anyway, cam, how much timing were you running? I"m currently on a 2.5 pulley, NO COOLING UPGRADES, full exhaust, intake, and 100 octane pushing 23 degrees of timing. I might be bumpin up to 24 soon...since i get zero knock
Old Mar 18, 2007 | 10:59 AM
  #86
blown06's Avatar
no good you need cooling mods
Old Mar 18, 2007 | 11:02 AM
  #87
tityrous's Avatar
sorry to say dude but im betting its ur piston i thought mine was a valve also.... start looking up those mahles u want....
Old Mar 18, 2007 | 11:53 AM
  #88
06blackg85ss's Avatar
yeah it's def a piston... if you tried it out again, did it blow the dipstick again? also check you COP's (coil on plug) swap em around and see if the same cylinder is dead.
Old Mar 18, 2007 | 02:08 PM
  #89
Cobalt_Supercharged's Avatar
After he cleaned up the mess he drove it home and has started it a few times since. The dipstick hasn't moved and the car doesn't smoke. Looks promising, but he says that since the engine is already open he is gonna build it. Unfortunately the Mahle pistons have the wrong size wrist pin so they won't work with the LSJ rods.
Old Mar 18, 2007 | 03:40 PM
  #90
Red2.4SS/SC's Avatar
hell if your gonna put pistons in why are you keeping the stock rods , what else is gonna happen blown4???? how much do you think the rebuild will run you
Old Mar 18, 2007 | 03:52 PM
  #91
Coblt ss super's Avatar
haha can i ask why the exhaust sounded like an sti exhaust at like the end?
Old Mar 18, 2007 | 04:08 PM
  #92
IonNinja's Avatar
so much for that awesome tune!
j/k man but hope you're puttin in some OT at work that build is gonna be expensive.
Old Mar 18, 2007 | 04:10 PM
  #93
Tofu's Avatar
Definitely run a compression test my friend.
Old Mar 18, 2007 | 05:01 PM
  #94
BlurpleSS's Avatar
Sucks cameron... but we all said it would happen! haha. gl rebuilding
Old Mar 18, 2007 | 05:09 PM
  #95
Blown 4-banger's Avatar
Yeah, it was bound to happen eventaully. I might take a loan out for the parts... there will be a lot
Ferria big bore valves
Ferria 8500 rpm valve springs
Cometic head gasket
Golden eagle head studs
8.5:1 pistons
Custom grind cams
netural balace shafts
severly ported head
and one other thing I can't seem the remember right now....
Old Mar 18, 2007 | 05:26 PM
  #96
IonNinja's Avatar
Cometic head gasket
8.5:1 pistons
Custom grind cams
severly ported head
que? aren't you going the wrong way...up the compression!
Old Mar 18, 2007 | 05:54 PM
  #97
8cd03gro's Avatar
....that one other thing he is forgetting is probably the twin screw kit or a turbo setup....that's what i'm guessing. and if he can push more boost efficiently, he is better off dropping the compression.
Old Mar 18, 2007 | 06:19 PM
  #98
ExHondaMan's Avatar
Domestics Pwn
Hey Cam... How far apart is the motor. If you still have it assembled I can get you a compression and leak down tester if you'd like. Let me know. I really dont think its a burnt valve... doesnt really make sense to me.
Old Mar 18, 2007 | 06:40 PM
  #99
Why would I UP the compression!?!? I'm already runnin 20 pounds of boost, more compression would be useless without 100+ octane all the time. I want to be able to run pump gas, also after the twin screw I will be able to run over 30 pounds of boost. 8.5:1 pistons + lots of boost = recipie for a VERY pump gas friendly car
Old Mar 18, 2007 | 06:50 PM
  #100
memphisr24's Avatar
30 lbs of boost would be niCe! ..... I don't think you'd be able to do taht with the whipple....i'm guessing you're going the turbo route? Good decision. I want to go that way eventually but I probably won't because of no funds
