225/40R18 or 225/45ZR18
Old Mar 30, 2007 | 07:32 PM
RickZ28's Avatar
Hi , i need help to choose my new tires.
I'm running on Eibach Sportlines and i want to buy BF Goodrich GForce KDW
but i'm unsure of the best size for me
225/40R18
or
225/45ZR18
any advice or comments will be appreciated
Thanks in advance
Old Mar 30, 2007 | 07:35 PM
AROON02's Avatar
Hey I Know It Has Nothinig To Do With Tires, But You Should Get A 2.7" Pulley
Old Mar 30, 2007 | 07:38 PM
Red2.4SS/SC's Avatar
if hes not running 60lbers then theres no way in hell he should quit giving members bad advice
Old Apr 2, 2007 | 07:37 PM
RickZ28's Avatar
Will i get any rub with 225/45ZR18 on sportlines with stock SS/Sc Wheels ?
Thanks
Old Apr 2, 2007 | 07:45 PM
Monster Midget's Avatar
go with 225/40
Old Apr 2, 2007 | 07:49 PM
silversccoupe's Avatar
Cool
Thanks
Our stock rubber is 25.7 inches tall. The 225/45 BFGs are I believe 25.9 inches tall.The 225/40 tire is a little shorter 25.4 I think .So your not talking about a huge difference.As far as fender rub with the Sportlines goes I don't think you will have trouble but I'm not using that spring so I can't say for sure.I'm using Toyo Proxes 4 in the 225/45 as it gives a little more sidewall to absorb shock as there are a lot of potholes here that you sometimes can't see,and bent wheels suck if you know what I mean.Good luck.
Old Apr 2, 2007 | 07:58 PM
chevy454400205's Avatar
for what its worth i run 235/40ZR18 with no rubbing issues at all.
Old Apr 2, 2007 | 08:02 PM
RickZ28's Avatar
Do you run it on stock rims & sportlines ??
Old Apr 2, 2007 | 08:06 PM
potatoe's Avatar
Im lowered and run 225/40's
Old Apr 2, 2007 | 08:35 PM
The stock wheels are 18X7 so the 225 tire is about as wide as you should use and still be able to keep a flat footprint on the ground.Most guys running fatter rubber are using aftermarket wheels usally 18X8 .
Old Apr 3, 2007 | 07:20 PM
RickZ28's Avatar
I finally fell for the 225/45ZR18, i'll let people know if i made a good choice
Old Apr 3, 2007 | 07:31 PM
im running 235 40 18 dot compounds on stock rims
crashher0
Wheels and Tires
Jan 29, 2015 08:06 AM
futuresseric
Sep 24, 2013 09:57 AM
Drew_224
Oct 19, 2012 05:34 PM
SSBlazer2007
Sep 29, 2008 06:20 PM
