!centric ring help!
Old Apr 2, 2012 | 11:11 PM
rcsrracing15's Avatar
!centric ring help!
i bought some 25mm adapters. 5x110 to 5x110. the center bore is 65.1. I have a 2007 ss/sc. I just bought a stock set of 2009 ss/tc rims. What size hubcentric ring do i need for these?
Old Apr 2, 2012 | 11:32 PM
casionerd's Avatar
village idiot
The SS/TC rims fit on a 65.1 hub. That's what's stock on the TC.
You bought 25mm adapters for the same bolt pattern? Isn't this essentially like getting a 25mm spacer? The TC rims have an offset of +42. You're gonna end up with something like a +17 offset that will poke a LOT.
Old Apr 3, 2012 | 12:22 AM
yeah it is. if i roll my fenders a ways will that clear up some of the gap? im not too worried about poke cause thats what i was going for. but i could clear up some gap by rolling?
Old Apr 3, 2012 | 12:26 AM
user 70823082's Avatar
You wont get much out of rolling your fenders.
Old Apr 3, 2012 | 12:33 AM
it shouldn't be outragous though about an inch or so. we will see how it works.
so i need a 65.1 centric ring?
Last edited by rcsrracing15; Apr 3, 2012 at 12:33 AM. Reason: Automerged Doublepost
You want to poke an inch?
Yes 65.1
Last edited by user 70823082; Apr 3, 2012 at 12:33 AM. Reason: Automerged Doublepost
Old Apr 3, 2012 | 12:48 AM
i dont really mind cause im only a 18x7.5 rim it will give me an aggressive look lol SPOOLED is a good example he has +16 on the front with a 17x8 adapters
Old Apr 3, 2012 | 03:33 PM
casionerd's Avatar
village idiot
They'll poke but the concave will look like a +42. Instead of making your wheels look deeper it'll look like your axles are wider. Don't know if that makes sense.
If you get them to fit, you should consider a set of rims with a low offset that bolts up to the factory hub. Then you'll not only poke but you'll have nice concave.
Old Apr 9, 2012 | 08:59 AM
i guess ile have to try that. butuntil then what centric ring size would i need. the center bore os 65.1 and i would need a 65.1 ring right?
Old Apr 9, 2012 | 09:13 AM
wouldnt i need like a 65.1 to 65.1 ring right?
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
SlowSaturn
Sep 28, 2015 11:03 AM
