!centric ring help!
!centric ring help!
i bought some 25mm adapters. 5x110 to 5x110. the center bore is 65.1. I have a 2007 ss/sc. I just bought a stock set of 2009 ss/tc rims. What size hubcentric ring do i need for these?
You bought 25mm adapters for the same bolt pattern? Isn't this essentially like getting a 25mm spacer? The TC rims have an offset of +42. You're gonna end up with something like a +17 offset that will poke a LOT.
yeah it is. if i roll my fenders a ways will that clear up some of the gap? im not too worried about poke cause thats what i was going for. but i could clear up some gap by rolling?
it shouldn't be outragous though about an inch or so. we will see how it works.
so i need a 65.1 centric ring?
Last edited by rcsrracing15; Apr 3, 2012 at 12:33 AM. Reason: Automerged Doublepost
They'll poke but the concave will look like a +42. Instead of making your wheels look deeper it'll look like your axles are wider. Don't know if that makes sense.
If you get them to fit, you should consider a set of rims with a low offset that bolts up to the factory hub. Then you'll not only poke but you'll have nice concave.
