Cobalt SS 17 inch rims
Old 03-19-2011, 11:09 PM
marcod13's Avatar
do 225/50R17's fit on the stock 17 inch rims?
thanks
Old 03-19-2011, 11:22 PM
marcod13's Avatar
Cobalt SS 17 inch rims (stock)
the speedo diff will prob be slower than actual speed
but will they be ok? safe at least?
thanks.
Old 03-19-2011, 11:59 PM
munit06SS's Avatar
thanks.
the stock 205/50/17 is 25.1" overall diam.
a 225/50/17 is 25.9" overall diam.
yea they'll fit, 225 is the widest (so i've been told) you can fit on the stock 17's
However depending on your suspension setup you may have rubbing issues with 225/50's. i cant say for sure because i cant test it, perhaps someone else can or has already and can chime in.
I personally was going to go with 225/45's seeing as they were much closer in overall diameter to the 205/50's. But if you dont mind the speedo being off some, then go for it.
Old 03-20-2011, 12:42 AM
futuressturbopurchas's Avatar
Try this cool tool I just found...Tire Size Calculator - tire & wheel plus sizing
Old 03-20-2011, 01:11 AM
Moderator Alumni
Erod's Avatar
yes, which I posted....in the correct forum. pls note..
moved!
Old 03-20-2011, 08:06 AM
marcod13's Avatar
thanks, yeah it'll be the stock suspension i'm not sure if that will rub though, i'd imagine it won't. thanks again!
Old 03-20-2011, 08:08 AM
marcod13's Avatar
moved!
sorry i posted in this forum, i made a new post in the correct one, i only realized after there was a tire one, noob sorry
thanks !
Old 03-20-2011, 10:27 AM
Moderator Alumni
Erod's Avatar
lol ok
Old 03-20-2011, 10:28 AM
Moderator Alumni
Erod's Avatar
merged threads
Old 03-20-2011, 10:57 AM
LS6Rally's Avatar
i have 225/45 and they fit great. sidewall is even with the rim face, and it looks great, i think it handles better.
as said 225/50's would sit higher
06blackbalt
10-05-2015 02:27 PM
jmelton327
Wheels and Tires
10-02-2015 01:54 PM
Cptnslo
09-24-2015 09:32 AM
Albertsstc09
09-16-2015 08:18 AM
Redspire
09-16-2015 07:08 AM
Quick Reply: Cobalt SS 17 inch rims
