Old Apr 29, 2013 | 08:50 PM
  #8501
stealthy1ss's Avatar
Old Apr 29, 2013 | 08:55 PM
  #8502
c130aviator's Avatar
ordered some wheel blanks, having them drilled to our bolt pattern. Going to take a few weeks however.
Old Apr 29, 2013 | 08:58 PM
  #8503
GoodLuckBro's Avatar
Originally Posted by Wert842
You can run 1" adapters on TC wheels and be flush as can be with the fenders. I've seen multiple guys on instagram have them too. LNF_monster and DB_lsj_4 are some for example.
I'm thinking maybe some sportline springs (for now) and maybe some 5mm adapters. Wert, you'll have to show me the 1" adapters at a meet. I'd be fine with flush for right now until I drop money on coils and new wheels.
Old Apr 29, 2013 | 09:15 PM
  #8504
BPacak's Avatar
Vtec Rep
5mm really isnt gonna be noticeable.
Old Apr 29, 2013 | 09:24 PM
  #8505
dakotaspeir's Avatar
#cobalthoes
5mm of fury
Old Apr 29, 2013 | 09:33 PM
  #8506
what you know about lip lowwwww
charlie sheen all about that mirror lip, if u "nose" what i mean
Old Apr 29, 2013 | 09:34 PM
  #8507
iToastie's Avatar
1" or gtfo
Old Apr 29, 2013 | 09:48 PM
  #8508
[IMG]http://i741.photobucket.com/albums/xx55/sergiochaotik/liplow.jpg[IMG]
those cars are freaking awesome, tone down the lip and the spolilers and they would actually look good. LOL, that lip is epicness, so awesome, behold its downforce.
Old Apr 29, 2013 | 09:51 PM
  #8509
Would 1" be a better idea to run with tc wheels?
Old Apr 29, 2013 | 09:56 PM
  #8510
BPacak's Avatar
Vtec Rep
just read through this, youll figure it out.
https://www.cobaltss.net/forums/whee...er-kit-286354/
Old Apr 29, 2013 | 10:03 PM
  #8511
Thanks man!
Old Apr 29, 2013 | 10:05 PM
  #8512
how many you guys rubbing or dailying that low with that much poke/flush? Any compression of the springs would rub hard. Do you just put height back in with coilovers for dailying?
Old Apr 29, 2013 | 10:08 PM
  #8513
Wert842's Avatar
DB_LSJ_4s car....
Old Apr 29, 2013 | 10:11 PM
  #8514
#cobalthoes
Im not as low as everyone. My fender to tire is a little under 24 inches, but Im running a 215/40 on my 17x9s and i dont rub at all. Just drive more carefully lol
Old Apr 29, 2013 | 10:12 PM
  #8515
Wert842's Avatar
im not as low as everyone. My fender to tire is a little under 24 inches, but im running a 215/40 on my 17x9s and i dont rub at all. Just drive more carefully lol
why no racecar??
  #8516
BPacak's Avatar
Vtec Rep
did you just say 24 inches? wut
Old Apr 29, 2013 | 10:13 PM
  #8517
#cobalthoes
haha yeah from top of fender to bottom of tire :/
why no racecar??
because cobalt.
Last edited by dakotaspeir; Apr 29, 2013 at 10:13 PM. Reason: Automerged Doublepost
Old Apr 29, 2013 | 10:16 PM
  #8518
Omiotek's Avatar
needs more tire.......oops let that slip....... getting 245s tucked would require a lot of pull
Old Apr 29, 2013 | 10:21 PM
  #8519
"make car as undrivable as possible for maximum street cred", I am trying to get away from this mentality when going for the right look on my car but I just see a lot of scraped/bent fenders, cut up tire sidewalls, and no fun on the crappy crappy roads here on the way to my base.
I ordered blanks to be drilled at 5x110, 35mm offset on an 18x8 wheel. Hoping to just be flush or just under that on a 225/40
Old Apr 29, 2013 | 10:22 PM
  #8520
my front on my 18x8 235/40 was 23 3/4 and the rear 24 3/4
right now idk 18x7 215/45 a bit higher off the ground plus the rear is up 1in to help with the 45 series
  #8521
DB_LSJ_4s car....
Yessss ill take that! Gotta set that up!
Old Apr 29, 2013 | 10:23 PM
  #8522
#cobalthoes
I wish I could go way lower, but as of right now my exhaust sounds like its going to die from the dips in my driveway
Old Apr 29, 2013 | 10:25 PM
  #8523
#cobalthoes
This is when I had my 235/40s and about 4 threads left on the rears and 6 on the fronts
Old Apr 29, 2013 | 10:26 PM
  #8524
do you take the wheels off to adjust height?
  #8525
mmmm
