Old Apr 29, 2013 | 10:27 PM
  #8526
dakotaspeir's Avatar
#cobalthoes
do you take the wheels off to adjust height?
Yes sir
Old Apr 29, 2013 | 10:29 PM
  #8527
BPacak's Avatar
Vtec Rep
waiting on a email from stance to get new shocks and get my car back on the road.
Old Apr 29, 2013 | 10:30 PM
  #8528
#cobalthoes
i've been wondering why I havent seen any new pictures of your car Lol
Old Apr 29, 2013 | 10:32 PM
  #8529
Omiotek's Avatar
yep imdebating what i wanna do here....go somewhat low again and spend huge dollars on coilovers or forget being low and run my koni powell setup and be happy. 245 40 18s on 18x9 +35
  #8530
BPacak's Avatar
Vtec Rep
yeah i really havent drove much at all, and its just now starting to get nice out.
Old Apr 29, 2013 | 10:33 PM
  #8531
Omiotek's Avatar
glad i ditched my stances when i did.
Old Apr 29, 2013 | 10:34 PM
  #8532
c130aviator's Avatar
i just went out and measured 26-1/4" rear and 25-1/2" front, I am on CM springs. I may cut the rear down 3/4" to level it out.
If I go 3/4" lower my tire will be on the fender on my current stock 18" wheels. On my new wheels the tire will stretch hopefully allowing me some room. I am going to have to get coilovers next just I wont be able to run as hard as I usually do without rubbing, I would rather have a fast daily than a take it slow cause my wheels rub daily.
Old Apr 29, 2013 | 10:35 PM
  #8533
he has ksports, i think he going with stance shocks in the rear to have shock height adjustable
Old Apr 29, 2013 | 10:36 PM
  #8534
#cobalthoes
I use my bike for when I wanna go fast, Use my truck when I wanna go offroading, and drive my cobalt when im trying to pick up guys Im lucky if I ever go 60 in my cobalt.. Just dont feel like getting a ticket and having the insurance raise. With a bike, cops dont even try lol
  #8535
go with the powell, performance over looks all day long. I am trying to balance this too man. I have custom wheels ordered for lighter weight and wider tires for performance but I went with a 35mm for a wider look but now I am juggling the right look with a great driver.
Old Apr 29, 2013 | 10:38 PM
  #8536
i do some pulls here and there and take corners like a boss, it might rub or scrape but its not bad
people that arent even on lowering springs hitting their bumpers on dips going into parking lots
makes u a better driver and more attention to detail of the roads
Old Apr 29, 2013 | 10:39 PM
  #8537
Omiotek's Avatar
eh i hated the stance stuff.... ive made it known to th motorsports too although i was going to prototype the pro comp 2s for um but decided they arent worth the coin.
im probablly going to stick with powells stuff. hes my friend and his stuff is proven and it works for me great on the track. if i was to pull his setup it would be for a set of $5k koni coilovers.
my car looked good on his setup with the 245s but looking at it with stock wheels on makes me hate the ride height....springs here though.
Old Apr 29, 2013 | 10:42 PM
  #8538
handles better than a roller coaster, beefy is fine in my eyes
your car look similar to Powells redline? but he on 255 tho?
Old Apr 29, 2013 | 10:49 PM
  #8539
Omiotek's Avatar
we run the same size tire 245 40 18s but hes on a 18x9.5 i run a 18x9. his i believe are +35 too.....redlines have a bit more clearence i believe but he does rub somtimes.
my cars handles amazing..... i have a complete set of sphericals in the leading and rear cabs, konis, powell v1 springs, modified twisting beam with some differences from its previous modles(wish i would of gotten the camber adjustment though), xxx bar, adjustable front sway bar end links, rotated mounts, under car rails and so forth. the car does its job and proves itself to time and time again. i cant complain honestly.....just want it a bit lower
Old Apr 29, 2013 | 10:51 PM
  #8540
Omiotek's Avatar
here ya go....not the best pic but yeah
Old Apr 29, 2013 | 10:59 PM
  #8541
sharp shooter right there, powell coilover prototypes will seal the deal and have your top notch handling to boot
Old Apr 29, 2013 | 11:11 PM
  #8542
that is the gap I have right now, my stock wheels are offset in more but I should be about there with my CM springs and my new wheels. Those are powell V1 springs? what changed on the v2? I like that ride height and I think I am going to swing to powell parts. There is no denying their performance based on user reviews and times.
Old Apr 29, 2013 | 11:25 PM
  #8543
v2 are a .10 shorter jk idk the details just they go a littler lower
Old Apr 29, 2013 | 11:28 PM
  #8544
lol, I deserved that one. I have been reading the threads about them with Konis
Old Apr 29, 2013 | 11:29 PM
  #8545
Omiotek's Avatar
the v2 springs are i think .5'' lower in the rear to even the car out. the rates are 2lbs less in the rear which is nothing
yeah its not worth it for himto do so....good coilovers cost over 2500 easily.
my car did work on the track this year with cars that should of out did mine easily......... they did on the straights but that was it....they had easily 150hp more or more then that... i dont even have a tune init lol
Old Apr 29, 2013 | 11:31 PM
  #8546
from CED... compared to v1, drop additional 0.350-0.400”Front and 0.750” Rear
Old Apr 29, 2013 | 11:32 PM
  #8547
i was close
u cant go wrong with that setup
Old Apr 29, 2013 | 11:36 PM
  #8548
Omiotek's Avatar
yeah i mean its a minimal margin but if you want a good riding good handling spring theres no comparison.
Old Apr 29, 2013 | 11:42 PM
  #8549
are your rotors facing the wrong way?
my stannnce
check out dis ill wheel fitment yo
Old Apr 29, 2013 | 11:47 PM
  #8550
Omiotek's Avatar
rotors manufactuers make the rotors differently....depends where you get them from....... the way the slats go in the rotor doesnt matter as they will still do their job what matters is the vent direction.
