Its pretty possible. I trapped 109.7 on the stock head and stock cams, bit on street tires. It's on a catted DP and stock catback though now. The red car will probably just get kicked off the track for no cage lol
I know most of you are on coils...I've got my ksports set to full low in the rear with no lock rings. I just noticed that my rear shocks are fully compressed when its sitting on the ground. Is this right?
I just wanted to make sure...I've never had a car this lowered...only really dealt in lowered trucks so when I saw the shock was fully compressed I just wanted to question. This is also the first time I've worked with coilovers...sorry for the stupid questions I just wanted to make sure I wasn't breaking something.
Going low is cool, but having zero travel and no rebound isn't and is in fact very dangerous as your car could skip and put you into a ditch.
Pics of shock if you can sneak one through the rear wheel?
its normal ksport activity. the rear springs are 4k and the shocks arent adjustable length wise to set any preload.
i have had the ring spun all the way down, no problem. took it in the canyons and on a small go kart track. had less aggressive wheels
now the rings are spun up about an inch in the rear. bounces but its normal bounce
This is a prime example of improper suspension travel/adjustment/setup.
Pics of what? My rears are set to full low which are causing the rear shocks to fully compress. It's pretty simple. Even raising it an inch I'm pretty sure the rear shocks will stay compressed. The shocks are the same size as the factory shocks. I only dropped the rear about 1" more than the canucks.
