Old Aug 11, 2015 | 03:59 AM
  #12801
Photoshoppppp
Old Aug 11, 2015 | 01:36 PM
  #12802
hahaha its real life
Old Aug 11, 2015 | 01:37 PM
  #12803
Dipped_Cobalt's Avatar
^^ if it was real, it would have m52s
Old Aug 11, 2015 | 02:43 PM
  #12804
07blackg5's Avatar
Slobodan Milošević
found out the inside of my rear wheel lips and tires have been rubbing on my ebrake cables
Old Aug 11, 2015 | 03:24 PM
  #12805
Old Aug 11, 2015 | 05:46 PM
  #12806
Zip ties fix this
Old Aug 12, 2015 | 03:33 PM
  #12807
07blackg5's Avatar
Slobodan Milošević
burning the car down would fix it too
Old Aug 12, 2015 | 10:31 PM
  #12808
BPacak's Avatar
Vtec Rep
this, I've thought about it myself quite a few times.
Old Aug 12, 2015 | 10:38 PM
  #12809
Youre alive?
Old Aug 16, 2015 | 09:09 PM
  #12810
CobaltSS 16's Avatar
I think I'm the only balt rocking the polished es2s ... dom ran 17s back in the day iirc.
anyways, some new pics now that its dialed in a bit more and clean. jumping up to wider tires next season. wanna drop the rear a bit more.
Old Aug 16, 2015 | 10:11 PM
  #12811
Looks clean af man. Now lower it
Old Aug 17, 2015 | 08:19 AM
  #12812
thanks bro ... happy with how it sits now.
My stance coils are maxed right now with locking rings out. Do you know if I take the perch out the rears it may drop it a few mm? Or if I adjust the shock (I don't think that'll effect ride height though) I was looking into swift springs to modify them into my coils, but probably won't do that for a while.
I may wait until I get wider tires to do some more adjusting. I think they'll fill it a little better... its pretty tight in there as is (no wheel gap in front- they're tucked, rear has like a half a pinky lol). Pics are deceiving.
Old Aug 17, 2015 | 09:06 AM
  #12813
bmxracerchamp12's Avatar
i pulled my rear adjusters out and it dropped a good bit. now i had to make a piece to keep the spring centered like the adjuster does
Old Aug 17, 2015 | 03:42 PM
  #12814
It will drop a small amount if you take the perches out
Old Aug 17, 2015 | 05:45 PM
  #12815
Kyle09TC's Avatar
I have the same custom stances you have and i run them with the perches out. still not low enough. I thought about shorter springs but my shock won't lower anymore and i don't know how i will keep the shorter spring in the the shock can't adjust that low. -.-
Old Aug 17, 2015 | 07:46 PM
  #12816
Theyve never fallen out on me and mine were like that for a long time
Old Aug 18, 2015 | 09:10 AM
  #12817
thanks guys.
kyle - no problems with the rear springs falling out? How much did it drop when you pulled the perches?
slowbalt - what coils you running?
Old Aug 18, 2015 | 10:04 AM
  #12818
I had regular bcs now i have randy coils
Old Aug 18, 2015 | 06:31 PM
  #12819
Kyle09TC's Avatar
thanks guys.
no the springs haven't fallen out. when the car is jacked up you can wiggle the springs but there is no way it will fall out. If the spring was an inch shorter it could though. You won't get a whole lot lower, maybe half inch or so.
Old Aug 20, 2015 | 02:37 AM
  #12820
bspeed's Avatar
Old Aug 20, 2015 | 03:39 AM
  #12821
Looks awesome as always man
Old Aug 20, 2015 | 10:21 AM
  #12822
bspeed car is purtyyy as ***
Old Aug 20, 2015 | 10:22 AM
  #12823
those are nice.
thanks.. good to know. and ill take a half inch in the rear #nohomo lol
Old Aug 20, 2015 | 10:33 AM
  #12824
bspeed: beautiful
Old Aug 20, 2015 | 12:23 PM
  #12825
