Different Tire Sizes?
Old Mar 18, 2007 | 11:51 PM
Tung's Avatar
hey everyone, is it alright to have different tire sizes? say like 215/35/18 's in the front and 225/40/18's in the back?? does it make a difference at all? or should i go the other way around with the 225's in the front and 215's in the back?
Jimmy
Old Mar 19, 2007 | 12:29 AM
EtyrnuSS's Avatar
You would be better off either keeping the same size all around, or if you want to stagger, put the wider ones in the front, since those are your drive wheels.
Old Mar 19, 2007 | 12:41 AM
Archie's Avatar
Jimmy
If your car has Anti Lock Brakes, your brake distances will be significantly longer. That is the only real problem, that is, unless your car is awd or 4x4.
Old Mar 19, 2007 | 03:45 AM
Tung's Avatar
can u explain how bigger tires would need more distance to stop?
Old Mar 19, 2007 | 03:58 AM
Archie's Avatar
We are tought this at work. I wasn't told exactly what happens, but this is what I determined.
Its not that it is bigger tires, it is that the front and back are different. The computer thinks they are still the same, and pulsates at the same speed for both front and back. One is pulsing different from the other, too fast of pulses and the tires do a basic slide, too slow, and your pads don't grip enough, not slowing you down as much. The brake distance difference is maybe 5-10 feet in this case. Nothing major, but enough to make a difference when you have to stop quick.
Old Mar 19, 2007 | 05:08 AM
Red2.4SS/SC's Avatar
can you explain why you want to put wider tires in the back , wider tires take longer to stop because they are heavier put wider tires in the front not the back
Old Mar 19, 2007 | 01:05 PM
Tung's Avatar
^ i dont know, for the look factor?
Old Mar 19, 2007 | 01:09 PM
normally people do that on mustangs and camaros RWD you drive a FWD
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
nathan112i
Sep 30, 2015 07:12 PM
