Disc Vs Drum!!!
Old Mar 17, 2006 | 10:06 AM
9JordonFlex9's Avatar
Disc Vs Drum!!!
We all know a lot of car drivers prefer disc brakes all around. For saving money I was looking at the base model, cuz the LT and LS will have the same results with turbocharging the engine...
How much better is having the 4 discs rather than 2 disc front and 2 drum back? besides apperance...
I have my 99 honda accord, it has this setup...the brakes are strong...except the front...I got to replace the pads...at 90k...I think they lasted a while...
Old Mar 17, 2006 | 10:17 AM
red_wing_2121's Avatar
You shouldn't notice a huge difference because at least 70-90% of the braking power comes from the front anyway.
Old Mar 17, 2006 | 10:27 AM
c7015's Avatar
I am no brake expert but most of the difference will come under heavy load and the ability of disc brakes to dispurse heat is far superior to that of a drum ..
EDIT: here is some more detailed reading for you
http://www.edmunds.com/ownership/tec...7/article.html
Old Mar 17, 2006 | 10:32 AM
alleycat58's Avatar
If you're going to be doing any heavy braking, like on a road course or something of that nature, you've got to have 4 disc. Rear drums just aren't going to cut it.
Old Mar 17, 2006 | 10:42 AM
R33P3R007's Avatar
360 L337 User
plus drums are such a pain to do a brake job on. disks are so much faster.
Old Mar 17, 2006 | 11:07 AM
freakaccident's Avatar
Depends on the car. My race civic did fine with drums but I liked it light in the rear so it worked out well. My miata had rear discs and I used a prop valve to adjust them so I could brake way late. Discs are not always necessary but they are definitely better.
Old Mar 18, 2006 | 02:14 AM
Dragonsfire12345's Avatar
I can feel a huge difference between my SS and my moms LS
Old Mar 18, 2006 | 03:55 AM
Badmunky's Avatar
The SS and the LS have two totaly diferant braking systems.
My cavy had drum rears and I never had a problem.
But I would prefer disks my self.
Later
Old Mar 18, 2006 | 04:53 AM
mi6_'s Avatar
As far as track use, you need the brake discs. They offer more stopping power and better cooling.
The SS models use different rotors and a high-performance brake pad. They are superior in every way to the non-SS model front rotor/rear drumb set-up.
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
09SSlow
Sep 28, 2015 12:37 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
