Hoosier 28-10-17 slicks, need tubes?
Old 03-16-2011, 01:59 PM
SOHC24powa's Avatar
I've searched this forum and google and I can't come up with a clear answer. it seems alot of camaro/charger guys use these but idk if they're running tubes. I don't know that much about the tube part of slicks to be honest so any insight would be helpful. do I need to run tubes on these Hoosiers?
Old 03-16-2011, 02:01 PM
EXsoccer1921's Avatar
are you trying to run them on your cobalt?
Old 03-16-2011, 02:06 PM
either way, people use tubes in their slicks because a race slick has such a thin side wall that it leaks air over time. you can run them with out a tube but you'll need to refill it every so often if you drive it on the street. and check your pressure after every pass if you want to remain consistent. however, advantages to running a tube inside the slick is it stiffens the sidewall up a little bit so there isn't a lot of wrinkle on the launch but still allows for some so there is still little to no spin. also, youre filling the tube, not the tire, so air leakage is no longer a problem. or, you could run a dot slick with a stiffer side wall. you'll spin a little bit more on the launch but you'll be able to drive it on the street, to the track, meets, etc.. and won't have to worry about it leaking air.
Old 03-16-2011, 02:10 PM
SOHC24powa's Avatar
yes on the cobalt. not worried about driving on them, gonna switch out in the pits.
so I should be good to go without tubes, because I don't think I could find any. or I'm just blind.
Old 03-16-2011, 02:13 PM
i don't even think a 28"x10" will fit on our cars. you'd have to make like a 6 point turn just to get off the track..
a 26"x9" is plenty of tire..
Last edited by EXsoccer1921; 03-16-2011 at 02:13 PM. Reason: Automerged Doublepost
Old 03-16-2011, 02:16 PM
SOHC24powa's Avatar
it's the only 17" full slick. they were gonna go on 17x7.5 +35 wheels.
Old 03-16-2011, 02:17 PM
yeah they wouldn't even fit on a 7.5, hoosier rates their tires by tread width. so that x10" is more like a 12" wide tire..
if you want a slick but still want a 17" go with m/t's bike slick.
Old 03-16-2011, 02:19 PM
SOHC24powa's Avatar
Hoosiers minimum spec wheel width was 8" so I figured .5" wouldn't hurt. and I've been looking for the 17" bike slick but can't find them. must be looking in the wrong place.
Old 03-16-2011, 02:23 PM
yeah, that is the absolute minimum. i wouldn't even get a wheel that is the minimum size. let me get you the link to the bike tires.
the reason the 28" isn't your best choice for these cars is one, theres just not enough room. and two because its too tall to get an effective launch out of. you may keep traction like a mother ****** but in return you won't be able to launch as hard and accelerate as quick trying to spin a 28" vs a 26" or 24.5". the setup i'm going with later this year is a 4.45 final drive a 24.5x8x15 slick. you can run your 28 and launch at whatever rpm you want. i'll run my setup and launch at 4k and we'll see who 60's first
Old 03-16-2011, 02:28 PM
Mickey Thompson Performance Tires & Wheels part #3221
Old 03-16-2011, 02:31 PM
SOHC24powa's Avatar
thanks. I'm not really looking to launch hard yet. I just don't want to spin anymore lol. 13.5@110 2.4 60' is the best I can get on the conti's.
Old 03-16-2011, 02:42 PM
you'll definitely benefit from the bike slicks then. those are what cmiller runs and he pulled a 1.8 60' on them iirc, maybe a 1.7 i'm not 100%
Old 03-16-2011, 02:43 PM
just sucks you guys have such big brakes lol. you'd be amazed at what that extra 1" of sidewall can do by dropping from a 17" to a 15" and still running the same tire height
Old 03-16-2011, 02:45 PM
SOHC24powa's Avatar
I couldn't sworn cmiller ran 24/8.5/15 on American racing wheels. or was that his setup before he got rid of the brembos. because I don't want to get rid of the brembos lol.
Old 03-16-2011, 02:46 PM
SOHC24powa's Avatar
I know don't remind me haha.
Old 03-16-2011, 02:49 PM
that was before he switched. maybe it was someone else haha, its been a while since i read it. but i know there was a bolt on tc pulling 1.7-1.8s on that slick i gave you the link to.
Old 03-16-2011, 02:58 PM
SOHC24powa's Avatar
that's good news. appreciate it man.
Old 03-16-2011, 03:33 PM
no problem.
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
yellow dragon
09-28-2015 09:49 PM
z28addiction
09-28-2015 12:03 AM
09-26-2015 06:44 PM
Quick Reply: Hoosier 28-10-17 slicks, need tubes?
