Need Help W/ My Winter Wheels!
Old Nov 8, 2007 | 09:04 AM
silver2.4's Avatar
A couple days ago I posted about my new wheels and tires. Well I've noticed when I cut the wheel all the way left or right, I hear what sounds like metal grinding. I pulled in the in the garage and took a look, and the wheel (not the tire) just below the bead rubs on the strut when its turned all the way. It's cuting up the wheel a bit. Granted it only happens when you turn the wheel all the way but I bought this setup from Tirerack.com understanding it would fit. Has anyone else noticed this problem? The wheels are Sport Edition CD's which are 16 x 7.5".... the stock 17" (being a little taller) would turn over the top of this bracket like area on the strut..I don't know if 16 x 7" would be any different. I just wanted some other opinions before I call up tirerack.
Old Nov 8, 2007 | 05:50 PM
SpecialK's Avatar
Call them up, and send them back. They said it'll fit, that's false advertising man.
Old Nov 9, 2007 | 11:09 AM
silver2.4's Avatar
The camera's upside down, but here you can see where the strut bracket is cutting a groove in the wheel
After further inspection, this was only happening to the driver side wheel. That groove is less than a mm deep. And it looks like the cause was actually a small bump (likely casting flaw) in the bracket on the strut. So I ground the bumb off and all is good again.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
