Offset Question
Old Mar 31, 2006 | 06:19 PM
2K5SS/SC?'s Avatar
Offset Question
Stock SS/SC 18x7" wheel offset is 42mm. I am going to 17x8" wheels. What offset am I going to need?
I used an offset calculator and at 42mm with the 8" ther is a .5" increase on each side.
With a 40mm offset, the wheel got pushed out toward the fender further, and with a 38 mm offset even more. Sort of confused because these wheels will be a special one time cut, and I want to get it straight! HELP ME please!!!
Old Mar 31, 2006 | 06:44 PM
GSoccer24's Avatar
38mm will be fine. our cars will fit probably close to 30mm offset with no problem.
i took some measurements the other day with a yard stick across the face of the wheel and up into the fender, then measured from the yard stick to the fender.
i don't like our stock wheels because they're tucked in too much. i like it when the wheels are almost flush with the fenders.
Old Apr 1, 2006 | 07:12 AM
2K5SS/SC?'s Avatar
Thanks GSoccer24. That waht I was thinking as well.
Are there any more inputs from people on here? I just want to be extra cautious.
Old Apr 1, 2006 | 10:49 AM
GSoccer24's Avatar
if it helps, the wheels i'm getting from my sponsor are going to be 35mm offset.
Old Apr 1, 2006 | 11:07 AM
2K5SS/SC?'s Avatar
What size width, and what brand?
Old Apr 1, 2006 | 11:15 AM
GSoccer24's Avatar
18" by 8", +35mm, Ace Alloy Wheel
Old Apr 1, 2006 | 11:23 PM
SilverSS/SC's Avatar
The lowest I would probably go on mine is 38 mm . Thats gonna stick the wheels out .670" more , and losing 9 mm on the inside . The fronts I wouldnt be worried about , but I think thats cutting it close on the rear as the rear wheels seems to sit further out than the fronts . 42mm will stick them out about an even 1/2 " . I will bring a yard stick and my digi calipers to the dragstrip tomorrow and see where exactly that comes out . Im still just visualizing at this point .
I want these wheels right too
Thanks for the input GSoccer24 .
The one possible issue I did see with a 35-38 mm offset on the fronts is a bracket mounted to the shock for a diagonal link . More with us going down a inch to a 17 . I didnt have my calipers handy to measure exactly , but it looks like about 20mm clearence between the stock wheel lip and this bracket . Of course though , it looks like if needed , it could be ground down a bit without effecting anything . Just a thought . I will try to get an exact measuremnt on that tomorrow too .
Old Apr 1, 2006 | 11:58 PM
GSoccer24's Avatar
sweet deal, good info man
Old Apr 2, 2006 | 01:17 AM
2K5SS/SC?'s Avatar
I appreciate it. We are all being so patient on these wheels.
Old Jul 16, 2006 | 06:24 PM
hardtocope's Avatar
so has anyone tried +38 offset wheels? I was thinking about getting 18's in that offset with a 225 tire and was wondering if it would rub?
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
